Sponsored by: Auxito
Crankshaft Seal Question
Old Nov 21, 2016 | 03:27 PM
Austin J.'s Avatar
Austin J.
I am installing the rear main and front timing cover crank seals. I am having trouble finding out which way they are supposed to be installed. There is no clear source and have seen conflicting instructions.
On the rear main, which side goes told the engine, the flat side or not flat side. Below is a rough cross section view. Which side goes towards the motor? The seal does have the taper like the drawing.
Below is the timing cover crank seal, which way does this go? Does the Shiny metal go toward the motor or away?
Thanks for the help.
Old Nov 22, 2016 | 11:11 AM
Austin J.'s Avatar
Austin J.
I have continued searching, but have still been unable to find appropriate instructions. Obviously this is important that they are in correctly and I don't want to have to change them after the motor goes into the truck. All help greatly appreciated.
Old Nov 22, 2016 | 01:33 PM
acogoff's Avatar
acogoff
The garter spring is always toward the side you want to keep the oil in.
sseebart
Aug 16, 2014 05:58 PM
theFear
Mar 23, 2010 07:24 AM
TMF
Apr 24, 2009 07:31 AM
otter 1
Jan 10, 2003 10:00 PM
