Three on the Tree or Floor shift?
Old Nov 21, 2016 | 01:50 PM
touchfordtruck's Avatar
touchfordtruck
I'm retromoding my 1965 F100 and was wondering what the consensus was on the forum with regard to three on the tree or floor shift. Shifting on the column isn't bad but I wonder whether a floor shift would be better or worse. Any recommendations from those who have tried both on these trucks?
Old Nov 21, 2016 | 03:00 PM
ulfie's Avatar
ulfie
I always thought column shifters were better because it allows your hands to be closer to the wheel and such have better control.
I'm also thinking that many young people have never driven a column shifter so that might add a little uniqueness.
As a side note, about 6 months back I noticed a DC drivers licence that restricted the operator to only vehicles with automatic transmissions!
Ulfie
Old Nov 21, 2016 | 03:14 PM
ulfie's Avatar
ulfie
After posting the last reply I began to think what a pain my floor shift lever is when my boys ride with me! The middle passenger is always having to move his knees to avoid getting slapped when I change gears.
The thought of an unrestricted bench seat reminds me of my old 79 f150 4x2 with an automatic transmission.
My wife (girl friend at the time), would enter and exit through my door as I held it open for her.
Old Nov 21, 2016 | 03:48 PM
daveengelson's Avatar
daveengelson
With two 65's, I have both, prefer the floor shift; having said that, unless the truck came with the 4 speed trans., I personally would not modify the 3 speed column for an aftermarket floor shift kit. The truck has retractable belts for the passenger and driver but does not have belts for a third person. For me, it comes down to belts vs shoulder harness when traveling with young kids; make exceptions if it involves local shopping or special events.
Old Nov 21, 2016 | 06:54 PM
john jamieson's Avatar
john jamieson
I also have trucks with both and really like the column shift and the clean floor area. That being said, four on the floor makes the truck feel more like a hot rod. If a '64 F250 with a stock 390 could ever feel like a hot rod lol.
Old Nov 21, 2016 | 07:03 PM
daveengelson
My experience with the 390 is not as much with mph but rather mpg?
Old Nov 21, 2016 | 07:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If a '64 F250 with a stock 390 could ever feel like a hot rod.
No such thing as a 1964 with a "stock" 390. The only V8 available in 1961/64's was the 292 2V
352 2V available 1965/67 F100/350, 360/390 introduced in 1968 F100/350.
The 4 speeds used in these trucks have a granny 1st gear, so most people start out in 2nd.
Old Nov 21, 2016 | 11:21 PM
RangerMercMan's Avatar
RangerMercMan
I believe the word "stock" refers to the 390 not being built up for speed. He did not mention it was "original" to the truck.
Old Nov 22, 2016 | 07:50 AM
touchfordtruck
The more I drive my 3 on the tree, the more I like having the shift close to the steering wheel. The only reason I was thinking of moving it to the floor is because I assume a new steering column made for a floor shift would be shorter. The steering wheel is currently in my face when driving and feels very awkward. I was planning on replacing the column with a flaming river tilt floor shift column and smaller steering wheel - maybe 15 inches for a more comfortable position. I drove my truck yesterday with the column shifter and now I'm thinking of getting a column shifter steering column. Any preferences for floor vs column shift?
Old Nov 22, 2016 | 09:00 AM
My1964ford's Avatar
My1964ford
How tall are you? Just curious... I'm 5'5" and I don't really feel like the steering wheel is really in my face..
I don't really have a preference but, my truck has the column shift and I like have the extra room for whoever is in the middle seat. You can also shift with your left hand so you don't have to remove your right arm from around that passenger/girlfriend (if you know what I mean). The main thing I don't like about the 3 on the tree is the fact that it is difficult to shift quickly at times.
Old Nov 22, 2016 | 03:49 PM
User 71024's Avatar
User 71024
I've had both, and like both, I would keep what it came with.
Old Nov 22, 2016 | 07:15 PM
john jamieson
Both ND and Rangermercman are correct on my '64. The engine seems to be a stock set up with the heads and block dating to '67. I knew it wasn't original to the truck because ND decoded the door plate for me when I got it.
Old Nov 22, 2016 | 08:23 PM
aj64f100390-292's Avatar
aj64f100390-292
does it have mid engine mounts...if so ...it took some finiglin to get it it..unless they used did what few have and knew how to mount it like a factory 292 bellhousing mount
Old Nov 22, 2016 | 09:24 PM
The Masked Rider's Avatar
The Masked Rider
I vote for leaving it stock, but it IS your ride.
Old Nov 23, 2016 | 05:36 PM
touchfordtruck
I'm 5'10" and feel like the wheel is in my face too. I'm planning to replace the steering column with a flaming river tilt steering and smaller steering wheel. Can't stand the wheel being in my face.
