E4OD soft/slipping 1-2 shift, slips in second, code 628, Updated
Old Jan 11, 2017 | 05:10 PM
Tom_Cat's Avatar
Tom_Cat
p { margin-bottom: 0.1in; line-height: 120%; } Just an update.
So fare so good, truck is still running good and second gear is rock solid! 10 ohm resister did the trick.
Has anyone used a resister in there EPC circuit to improve shifting?
I want to thank everyone for there help!
Tom_Cat
Old Mar 14, 2018 | 11:39 AM
Keenan Long's Avatar
Keenan Long
Trans slip in 2nd
Originally Posted by Tom_Cat
Hi all
I have a 1992 f150 5.8 E4OD 4x4 3.55, that is driving me nuts. It slips on the 1-2 shift under light throttle and slips in 2nd under light throttle in drive, if you Manuel shift it there is no slip.
If you step on it (more that ¼ throttle) it will go through the gears like a new truck, no slip!
If you Manuel shift it there is no slip, only in auto mode (gear selector in D), witch makes me think it is electrical and not mechanical.
It will also neutral out at a stop, give it a little gas, it will cache and away you go.
It dos not slip in 3rd or 4th gears and the tork locks up, (1900rps at 65 mph).
The only code is 628.
Things I have don so far.
Replaced MPLS with a known good unit (I now have backup lights).
Changed fluid an filter.
Checked TPS (.93V) and smooth through the range.
Inspected all wires.
Checked all fuses.
Check VSS (spedo works perfectly).
I am at my wits end and this thing has me stumped!
Any help will be greatly appreciated!
Thank you for your time!
Tom_Cat
Tomcat where did you add the 10ohm 20w resistor to on the ecm?
Tom_Cat
Nov 21, 2016 07:44 PM
sharp94xlt
24
Oct 13, 2008 04:22 PM
Vantss
Dec 11, 2006 09:49 PM
bedwards
1983 - 2012 Ranger & B-Series
Apr 2, 2004 02:59 PM
