HELP!!!
Old Nov 21, 2016 | 10:29 AM
Wingit929's Avatar
Wingit929
HELP!!!
Does anyone know of a system I can use to be able to use this method to tow my Jeep on a wooden floored trailer?
I currently have.....
PJ Trailers | 4" Channel Carhauler
Links would be great if you have them.
Old Nov 21, 2016 | 02:08 PM
senix's Avatar
senix
go to the hardware store and pick up some D rings.
Old Nov 22, 2016 | 02:16 PM
meborder's Avatar
meborder
are D-rings bolted to a wooden deck secure enough to be considered "secure"?
(asking, not criticizing)
there is one guy here using E-track, but I'm not sure about that solution either.
Old Nov 22, 2016 | 02:23 PM
senix's Avatar
senix
Valid question, I would think for this application it could be with good materials and perhaps increasing the number of them.
Ideally they should be welded to the sides of the trailer at least.
Old Nov 22, 2016 | 02:50 PM
Wingit929's Avatar
Wingit929
Ones like these can have a 5000 lb capacity. But you have to have a piece of steel on the other side for that rating. Usually the more expensive ones come with that backing plate.
Just D rings wont give me what I am looking for.
Old Nov 22, 2016 | 02:53 PM
Wingit929's Avatar
Wingit929
Going to go with this by Erickson MFG. Can buy it through etrailer.com
Old Nov 22, 2016 | 04:26 PM
meborder's Avatar
meborder
what's the rating on these?
(I guess I could go look for myself, but what's the fun in that?!?)
Old Nov 24, 2016 | 07:30 AM
FuzzFace2's Avatar
FuzzFace2
With any thing you go with you MUST use a backing plate to spread the load out or the bolts will pull thru the wood.
I would make the plate 1" wider all the way around the hold down you go with.
Min thick would 1/8".
So if using Etrack 4"x 5' the backing would be 6" x 5'2" would not hurt to go bigger.
Dave ----
Old Nov 24, 2016 | 10:00 AM
Wingit929's Avatar
Wingit929
Dave ----
I bought the Erickson backing plates. It is 6" X 6.5"
https://www.etrailer.com/Accessories...ophy/BPEZ.html
Old Nov 25, 2016 | 05:31 PM
FuzzFace2's Avatar
FuzzFace2
Nothing like getting plates that are made for the tracks!
It may not be a big deal with wood but if you use plates on metal make sure you round the edges of the plates on the side going to the metal or wood.
What happens with metal the sharp edges of the plate acts like a shear and cuts thru the metal the size of the plate.
Dave ----
Old Dec 8, 2016 | 11:39 AM
Wingit929's Avatar
Wingit929
I got scared away from this system and now just making my own. I am dropping angle iron (2X2x3/16) through the boards of the trailer. Holding them down with 1/2 grade 8 bolts to the trailer frame. Welding on 4000# WLL (12,000# breaking) D Rings to the angle iron.
rockymtns
Aug 16, 2017 11:14 PM
Sparkman1980
Washington Chapter
Sep 17, 2010 02:37 PM
Timon5435
All Things Towing
Jul 8, 2009 06:42 PM
Jeff3298
N. California Chapter
Jun 2, 2008 12:55 PM
Buckarcher
All Things Towing
Sep 18, 2004 08:52 AM
