High Revving, wtf?
Old Nov 20, 2016 | 04:38 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat
High Revving, wtf?
I noticed a few times that after starting the 5.0L engine, I hear a noise that sounds like high revving. Happens for example during multiple starts for short trips, like when shopping at multiple stores in close proximity 20 min trips apart. Lasts for a minute or two, and engine is already pretty warm from previous trip so why does it need to rev up? The climate system is switched off.
Not really sure if it is the engine running faster in short bursts, or some other "system" under the hood speeding up and then slowing itself down.
Is this normal or a problem developing??
Old Nov 20, 2016 | 05:21 PM
Schlotzky's Avatar
Schlotzky
From your description I would say this is the engine fans.
When you're driving around for extended periods, the coolant is continuously circulating between the radiator and engine block and being cooled by moving air. When you stop the engine at temperature, the engine temp actually rises beyond operating temperature before it begins cooling off because the flow of coolant has stopped and there is no air moving across the radiator, but there is still some heat transfer occurring from the combustion process. You may notice that your temperature gauge is above normal operating range when hot starting, so your fans kick into high gear for the beginning of your trip to get things back into normal range. Once the engine is cooled back to normal range, the fans slow back down to normal RPMs until another hot-start condition. This is all normal operation.
Old Nov 20, 2016 | 07:19 PM
Pcool69's Avatar
Pcool69
second the fans
Old Nov 20, 2016 | 07:27 PM
biz4two's Avatar
biz4two
Arrow
OP -- Next time this occurs...take a quick look at your Tach...and notice the RPM's.
I am inclined to believe it might be the fans, but verify with the TACH readings.
biz
Old Nov 20, 2016 | 08:29 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I'll 4th the electric fans. They seem to ramp up randomly on restarts at times.
Josh
Old Nov 20, 2016 | 09:48 PM
brokenleg's Avatar
brokenleg
Fans to me....
Old Nov 21, 2016 | 05:45 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
You should hear the fans on my daughter's 2015 Fusion 2.5L, sounds like a turbo prop plane coming in for a landing. I second the fans.
Old Nov 21, 2016 | 07:40 AM
Wiggums's Avatar
Wiggums
You're good.. it's just the fan. Pretty common.
Old Nov 21, 2016 | 11:16 AM
Big-Red-Lariat
sounds like the jury says it's the fans so I'll buy the verdict. ;-) Just wondering why we never heard this before on any of our previous F150 8cyl trucks (2003, 2006, 2011) or is this fan system contraption a recent invention and unique to current models?
So where are these fans anyway and can they be seen under the hood? Anyone got a pic?
Old Nov 21, 2016 | 11:52 AM
GlueGuy's Avatar
GlueGuy
What I'm hearing is the fan(s?) behind the radiator. Most new designs have electric fans behind the radiator that are controlled by the computers in charge.
Old Nov 21, 2016 | 12:15 PM
pikapp's Avatar
pikapp
I like the whistling turbo's at first start too.
Old Nov 21, 2016 | 06:01 PM
TJReams's Avatar
TJReams
Multiple starts in with short driving time will also draw down the battery so it could be the engine running faster to get a quick charge back into the battery.
Old Nov 21, 2016 | 07:28 PM
Bullitt390's Avatar
Bullitt390
Electric fans versus engine belt driven fans.
Also, the fans ramping up on engine restarts caught me off-guard a time a two after buying my truck.
Josh
Old Nov 23, 2016 | 04:07 PM
WordyBirdy's Avatar
WordyBirdy
Def fans i agree with all of you haha
orange57
Jul 30, 2016 04:11 AM
tiger_698
Jul 16, 2011 09:00 AM
302grabber
15
Jun 5, 2007 04:46 AM
Twin Tritons
Mar 2, 2004 05:51 PM
regierj
Apr 25, 2002 09:32 AM
