82 F250 - air cleaner intake tube?
I apologize if this has been asked previously. This is only my 2nd Ford, and my first since I was 16/17. I searched the forums and couldn't tell if the previous posts about this topic provided info that matched what I need.
My 82 F250 has a 400 V8, regular emissions. There is a 2 piece plastic air intake tube that goes from the radiator support to the air cleaner snorkle. The flexible piece of that air intake tube needs to be replaced. From what I read, I think that the 2 pieces may only be sold as an assembly, but I'm not sure. LMC Truck lists 2 different parts:
43-3575 is a 12 inch piece
43-3579 is a 25 1/2 inch piece
The flexible part I need is about 12 inches long, so I thought the first part listed might be what I need, but I honestly have no idea. Does anyone know?
1977/79 F100/350 351M/400 / 1978/82 Bronco 351M/400 / 1980/82 F150/350 351M/400 / 1981/83 F150/250 & Bronco 351W w/unleaded fuel.
LIVE OAK MOTORS in Three Rivers TX has 1 = 361-786-2547.
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
Bill, you are a wealth of knowledge. Thank you for all of your help.
In looking at that graphic, it looks different than what's on my truck, or I'm reading the graphic incorrectly. On my truck, the part that attaches to the radiator support looks like 9A624. The flex hose attaches to that part on one end, and to the snorkle of the air cleaner on the other end...at least, it would if it hadn't dryrotted and fallen apart. The graphic looks like the flex tube attaches to the actual body of the air cleaner. Is that correct? Or am I looking at it wrong?
OK. To make sure I understand, or to prove that I'm a moron (whichever the case may be), the duct and valve assembly (red arrow) attaches to the adapter (red arrow), and the end of the flex tube (green arrow) attaches to the rigid plastic intake duct (green arrow). So the graphic was created with the position of the duct/valve assembly and the flex tube flipped in the opposite direction of how they actually are when viewed from standing in front of the truck, looking at the engine? Did I get it right?
Let me try to attach this pic...
Dave ----
You guys make it sooo difficult. All that and more is documented: Air Cleaner Snorkels - ???Gary's Garagemahal.
Thank you everyone for helping out this newbie. Using the graphic posted from Gary's Garagemahal, I added a red arrow to the part that I need. Looks like it's 9C675? Bill, any luck with one of those being out there somewhere? Or does anyone else know if either of the LMC Trucks parts are correct? 9C675 is 2 pieces, but only sold OEM as an assembly, I believe.
