Spark woes
By the way, those readings of 500-1Kohms...(0.5-1ohms) when I mentioned it showed a shot stator... was wrong. Mea Culpa! I didn't know the meter was set high. I hope you didn't spend the bucks on a new one at my behest....if you did, please forgive...and send me the bill.
Again, all resistance measurements should be taken with the key off, yes?
Pulling my hair off on this one
Next steps checking spark plugs for carbon buildup.
The same test - coil batt terminal to ground - while running should be no more than 9 VDC.
If you could, check the distance between the stator and a reluctor tooth - should be 0.018." And all the wires/connections are good?
Just to be sure: You have fuel...the carb had nice squirts when you blipped the throttle, correct? And it's obvious you have air. That leaves spark. Besides checking the plugs, have you checked for spark yet? Results?
Step 1: install new plugs and wires
Step 2: ohm out new stator key off
It ran today when i kept a quarter throttle.
It started up on the second turn ran poorly for 2 minutes then died, started back up, with hints of starting as I let off the key(luckily I kept the motor craft stator I swapped out for a China brand).
I am using an accel universal 12v coil 8140c the plastic tower pushes against the rubber boot of the lead and backs the terminal off, anyone else use this coil? Or can someone suggest a wire designed to work with this high tower?
Running out of ideas I'm going to replace the coil lead and put back in the old stator. Still cannot get any response from either the purple or orange terminals to ground, supposedly this test should yield 70k ohms, anyone care to posit as to why?
Last edited by BigMightySam5600; Nov 22, 2016 at 01:54 PM. Reason: Omission of key point
Orange/purple to ground ohm test: No reading at all? That's an indication of a wiring/connection illness. Check/cajole/jiggle the wiring harness/wiring between the ICM and distributor...including the distributor connection/grommet....then re-ohm it out.
While you have the meter out, check the resistance on the ballast resistor wire, just to be sure it's functioning as it should: Disconnect the plug on the ICM with the RED and WHITE wires. Disconnect the coil's "horseshoe" conection if used. If you have just a eye terminal, disconnect it from the coil. Check the resistance between the BATT(+) coil wire and the RED ICM mating wire....I believe it would be a WHITE wire on the disconnected plug, which mates to the RED ICM wire.
Here, you're looking for 0.8 - 1.6 ohms. Anything more or less, the dreaded ballast resistor wire is pooched.
Again, all resistance measurements are taken with the key OFF....just sayin' that to repeat meself....I'm sure you know that.
thank you for the assistance, love my truck.
I checked the batt + against both sides of the icm mating plug, only one side had a reading of 1.2 ohms, no reading on the other side.
I am thankful for all the help on this thread!
So it seems the "dark side" of the ballast resistor wire isn't dark at all. One less thing to be perplexed about.
You're thankful for the help? No problem, Sir! Well, I thank you for your "Emily Post!"
'Tis the season, no?
We'll both be "thankful" when you're up and running!
How did the "jiggling" of the wire harness turn out? (Post #20, orange/purple to ground ohm test).
Your question of what ground to use brings up another question from me....how are your grounds? Engine to cab, BATT (-) to engine, BATT (-) to frame, starter solenoid grounded to clean, unpainted fenderwell, distributor base to engine?
I won't ask about the lights to ground, or dash grounding...yet...as you seem to have no problem there.
Next step go thru the aforementioned grounds..
I have also considered removing the aftermarket radio to address the hot blade inserted into the fuse box to give what I'm guessing is constant voltage to radio. Previous owner
Recently the door chime/seatbelt warning failed..I'm guessing these are related events but the original symptom was an experience like fuel starvation?
Also all electrical lights, signals, reverse lights, marker lights, inside lights, dash lights, stop lights, headlights, all work. Go figure
Emily post, that's a good one, I had to wiki that to apply appropriate sub context. As the kids say LOL
Just a question what can the dark side of the ballast wire with 1.2 ohms confirm?
Thank you
Last edited by BigMightySam5600; Nov 25, 2016 at 09:51 PM. Reason: Omission of key point
Original symptom was something like fuel starvation? Forgive me if I can't remember....that would indicate a fuel pump, float adjustment or accelerator pump starting to go south.
And... you're welcome, of course.
My 79(460) would pop on the "on" and not start on "start". It was the was the Box,tested with spare and it would start on "start"
Pulled two spade connectors from the fuse box now radio is silent, I guess they were for constant and switched ac?
One particular question , I have a random braided ground behind the carb on the cab that connects to nowhere, I'm thinking this is the engine ground?
Batt - goes to the engine block then a second ground from the engine block goes to the frame this appears to be a series configuration.
I had to wire in a secondary seatbelt with a working latch to get a working seatbelt tone, my guess is that connection went south, checking...
I cleaned up the starter solenoid ground, but without that retainer for the vacuum advance arm to the stator I'm stuck at this point, junkyard bound..
Thanks again
