Leaking transmission fluid
Old Nov 30, 2016 | 10:17 AM
  #31
RainDesert's Avatar
RainDesert
Why the heck would Ford change something that wasn't broke!? Frustrating for sure. I can only imagine it was a way to save a few bucks.......
I have the same "new style" connection on my 6r100, located on the drivers side.
Old Nov 30, 2016 | 10:30 AM
  #32
troverman's Avatar
troverman
And I think I have the answer, after talking to one of our engineers.
Right off, he said the new design will flow better through a bend vs the banjo-style connection. More torque = more heat in the transmission. So I think we see why the cooler moved, and the lines changed...its an effort to improve trans cooling. If more fluid can flow through the cooler than it will cool down the trans better.
However, he did say the old style appeared to be better at holding down the lines. I assumed the flat plate on the 2017 would flex more...but he said the 2016 bent design would actually be longer and some strength was lost by the metal fracturing as it was bent. Nevertheless, the banjo design appears to hold in place better.
So maybe not cost cutting after all, maybe a performance improvement, just need a way to keep the connections tighter.
Old Nov 30, 2016 | 10:36 AM
  #33
RainDesert's Avatar
RainDesert
Well that makes me feel better. I will keep an eye on mine, I don't think I have seen a 6.2 have a problem yet......
I don't recall over heating problems in the past that could have been associated to this clamp though.
Old Nov 30, 2016 | 10:44 AM
  #34
69cj's Avatar
69cj
You don't have to have a problem to improve something. Usually it works but sometimes it doesn't.
Old Nov 30, 2016 | 10:48 AM
  #35
troverman's Avatar
troverman
Would you mind snapping a pic of your cooler lines going into your trans? I'm curious to what it looks like. My understanding is that this *only* affects the 6R140 trans. I'm guessing it also only affects diesel models. Gas F-350's with the 6R140 use a radiator mounted "in tank" cooler plus an auxiliary small cooler in front of the radiator. Diesels only use the small, separate oil-to-coolant cooler (formerly located on the frame rail) located under the radiator now.
They may have used the same hold-down clamp to standardize parts and save money.
Old Nov 30, 2016 | 11:11 AM
  #36
RainDesert's Avatar
RainDesert
The picture is looking right over the front drive line.
Old Nov 30, 2016 | 11:26 AM
  #37
troverman's Avatar
troverman
Perfect, thanks RainDesert. It appears to be the identical hold-down plate, although it is mounted in reverse on this transmission.
Which side of the transmission are these lines on? Drivers or passengers? I'm guessing drivers because the shifter cable is usually on this side...
Old Nov 30, 2016 | 11:47 AM
  #38
RainDesert's Avatar
RainDesert
The connection is on drivers side. The lines come from the cooler along the passenger side, then 90 just past the bell housing, under the tranny. Then come up on the driver side, and to the connection in my picture.
Old Nov 30, 2016 | 12:00 PM
  #39
lts's Avatar
lts
So far mine is staying nice & dry.
Asked the guys at the dealership about it today and they pulled up this SSM.
Old Nov 30, 2016 | 12:38 PM
  #40
troverman's Avatar
troverman
Great info, thanks! Reps sent.
RainDesert, on the diesel, the tranny cooler lines are on the passenger side. Interesting. But looking at the statement lts just posted, it looks like you are exempt from the problem!
Old Nov 30, 2016 | 03:16 PM
  #41
Florit17's Avatar
Florit17
Maybe I dodged that bullet then. . . my build date was 11/4?
Old Nov 30, 2016 | 03:30 PM
  #42
oklarado's Avatar
oklarado
I would look for a fender washer under the bolt, that would be the difference.
Old Nov 30, 2016 | 04:27 PM
  #43
TXOILMAN's Avatar
TXOILMAN
Update: Picking Truck up in a few with new part installed with old bolt and washers.
Was able to get part installed with old washers. Dealer was not aware of bolt and washer info until I sent a screenshot of this site. Bolt and Washer are on order and I will run back up there to have them installed once they come in. The line is currently not leaking with new part and should hold for shuttling around town for a few days while bolt and washer are delivered. The picture of that document is key, check bolt and washer #'s.
Old Dec 10, 2016 | 04:33 PM
  #44
mlsjohn's Avatar
mlsjohn
Do they replace the cooler lines or just the bolt and washer and how long does it take?
Old Dec 10, 2016 | 04:50 PM
  #45
TXOILMAN's Avatar
TXOILMAN
They replace lines, washer, and bolt. Take a screenshot of that SSM posted and they'll know exactly what to do.
