Florida Rain Gutter rust on 95 E350..
POR-15® POR Patch
Use POR Patch and POR-15 on them and you shouldn't have any more issues for a long time. I'm going to be doing this on the rain gutters on my 89 E350.
And if you have any bigger holes they have some two part epoxy putty that works great. I'm going to be using this on my van too. I've got some rust holes starting at the top corners of my windshield post. And I don't want to remove the windshield and headliner to cut out the area and weld in patches. My van is going to be a work van/daily driver not a show vehicle.
POR-15 also has some fiberglass cloth that you use with POR-15 instead of resin if the holes are too big for the putty.
The POR-15 stuff isn't the cheapest but I like the results I get with it.
POR-15® POR Patch
POR15 says..
POR-15 is sensitive to UV light (sun) and must be topcoated before prolonged exposure to sunlight" But nothing about them making UV stable paint.
Granted POR15 makes some great products. But how many of those little tubes would it require to fill the entire gutter level so water runs off?
A fellow over on vanning.com posted a pic of a cross section of a dodge van gutter. There's so much going on there its hard to see exactly and imagine trying to rebuild that..
The reason Im now wondering, is the vertical outside edge of the gutter doesn't look like it crimps the top on. Maybe annaleigh's suggestion of removing at least the vertical section is possible so that water sheds?
Does anyone have a picture of the cross section of the ford gutter?
I started digging the old seam sealer out today but it looks like most of it is in good shape and I'm wondering why I'm digging the good old toxic stuff out. So far it looks like the seam sealer failed right where the crimped vertical side section was folded over the roof panel or the very top of the gutter. Some of it is completely rusted away and separating due to a roof rack I imagine.
Sounds good please let us know.
POR15 says..
It would take a few tubes of the POR Patch to do the rain gutters on a vehicle the size of a van. But you don't need to fill the gutters. After all they are rain gutters. They are designed to have the water run down them. You just need to clean them out good and seal them so moisture can't get between the different layers of sheet metal. The problem with a regular seam sealer is eventually it will fail. And when it does you have more rust issues.
The POR products aren't cheap. But once they are applied you don't have to worry about rust in that area again.
If you are going to use something besides POR-15 make sure to first use something that will remove or convert any rust that is there. If you don't the rust will just continue to get worse and worse.
Im just a little disheartened right now because I found that the back or rear part of my gutter is GONE in a spot and I haven't even made it to the rear doors yet.
Had I known it was this bad, I wouldn't have spent all the time and money I have on this van.
This is why I want to fill the entire gutter. To prevent water from sitting since there are no downspouts. lol. The only upside is that the lower half of the van is clean.
I know I will have a few spots that I will have to do this with.
I'm going to have to do this on one spot of the drip rail on my Ford bus pretty soon. Maybe even this weekend.
It took me longer than it should have, because I kept puking with disgust about how much drip edge was rusted gone. This is the last time I ever buy a vehicle on the word of the seller and pictures. Here's a video of why you should never park your econoline in a position where the water collects in the back. I will probably regret posting this if and when I try to sell it.
If it was mine I'd get them cleaned up as good as possible. Do the prep work for POR-15 ( their cleaner/degreaser & metal prep ) . Then lay down the POR patch to seal up the gutters. Then apply the POR-15 & paint, etc. And if you really want to completely fill the gutters. Do it after all the POR-15 products have been applied. Then you can use a cheaper product to do that with no worries. Like seam sealer in a caulking tube. Or hell you could even use some of that flex shot crap from the infomercials on tv!
And those rusted outer gutter rails are a perfect spot to use the POR epoxy putty. That stuff is easy to form and when it cures it is hard as steel. You are talking about some small sections of the rain gutter here not big rust holes in a frame rail.
It's not the end of the world. Jeremy, The surface needs to be down to bare metal or rust. Remove any loose rust.
Properly clean and prep the surface with our Cleaner Degreaser and Metal Prep. Each product is applied, kept wet 10-15 minutes then rinsed thoroughly with water and allow to dry. Once dry either apply two thin covering coats of POR-15 or squeeze out some of our Por Patch and run your finger along the drip rail. (wear gloves).
Allow the POR-15 to cure then scuff with a maroon scuff pad then apply your final color. Thanks, Mike
It's not the end of the world. Back on topic.. I'm considering west systems epoxy because I already have it, mixed with chopped fiberglass (better adhesion, less shrinkage) but cant make up my mind if to use POR15 epoxy putty. I wont try to build the missing vertical edge and have a gutter, but fill it flat like Iv already mentioned.
I have one section above the back door at least 12" long that's missing and I still haven't removed all old bondo yet.
http://vid640.photobucket.com/albums...pscpzrhp1y.mp4
Like I said in my other post. I would use their putty to reform/rebuild the gutter wall. That way it will look like there hasn't been a repair. Once it's repaired with the good products, that will end any further rusting. Then you can always fill the gutter with whatever product you want. I wouldn't use the POR putty for that, it would be way too expensive for that much filling. A seam sealer or some type of caulking is a better option for filling. If you fill it with something that hardens. There is a good chance it could eventually break/crack and pop/fall out. Because these van bodies can flex and twist some. But if you do use a seam sealer or a caulking you will want POR-15 or something similar under it. Otherwise you'll just end up with more and worse rust when water gets in under it.
