Slow cranking 460
Old Nov 16, 2016 | 05:48 PM
Dean06919's Avatar
Dean06919
Slow cranking 460
1996 F-Superduty, 7.5 L, ZF5.
I purchased the truck with it rolling over slow. I removed the coil wire, replaced the ground, positive cables, solenoid and battery. Starter was removed, all terminals and mounting points cleaned and tested. The no load test showed it wasn't drawing too many amps and was spinning quickly. I even ran jumper wires from the negative battery terminal to the housing on the starter, and from the positive to the ring and spade terminal. While all of this did speed it up a little, even with the jumper wires, it still rolls over slow.
Could the starter still be an issue, or do you think the problem is mechanical? I do not know the history of the engine. Starter is an OEM F37U-11131-CA. Is this a gear reduction starter?
cjben
Mar 16, 2016 03:54 PM
dracip
Jan 28, 2008 06:43 PM
JohnEnnis5786
1997 - 2003 F150
Sep 4, 2007 01:41 AM
cjf5150
31
Mar 17, 2006 05:47 PM
Dett
Feb 15, 2005 06:40 PM
