Truck bed test
Old Nov 16, 2016 | 11:25 AM
ssoundwave's Avatar
ssoundwave
Truck bed test
80 sheets of 3/8 OSB (1 full forklift lift plus more sheets under it)
i haven't done the math on the whight yet but surprisingly it didn't max out the suspension on my F350, and no damage to the aluminum bed! The fifth wheel prep kit and the spray in bedliner probably helped tho
Old Nov 16, 2016 | 11:41 AM
coolidge54's Avatar
coolidge54
Impressive! What are you building?
Old Nov 16, 2016 | 11:45 AM
wb6anp's Avatar
wb6anp
OSB about 1.2 lb/sqft, 4x8 sheet= 32sq ftx 1.2=38.4/sheet x80=3072 lbs. if my math is correct.
Old Nov 16, 2016 | 11:48 AM
ssoundwave's Avatar
ssoundwave
Math says 3072 LB or 1.4 m-tons but something tells me it was heavier than that!
im re-roofing a large house, removing cedar shake and installing osb then shingling it, shake roofs arnt always sheeted, this one is 1x6's every 10 inches or so
ssoundwave's Avatar
ssoundwave
lol you beat me too it
Old Nov 16, 2016 | 12:00 PM
biz4two's Avatar
biz4two
Arrow
Very impressive! You have OEM or aftermarket spray-on bedliner?
biz
Old Nov 16, 2016 | 12:22 PM
69cj's Avatar
69cj
Don't believe GM's propaganda. What will they be saying when they go to aluminum in 2018?
Old Nov 16, 2016 | 12:55 PM
fordmantpw's Avatar
fordmantpw
Who says you can't haul anything in the short bed?!
Old Nov 16, 2016 | 02:02 PM
Tom's Avatar
Tom
Did you seriously expect this to hurt anything? It's a pickup truck...this is what they're built for. The aluminum vs. steel thing is way overplayed IMHO.
If you're not dumping landscape block from 6 feet above the bed, or trying to puncture with sharp-edged metal boxes, that ad just doesn't apply.
ZooDad
All Things Towing
Oct 2, 2018 09:13 AM
Diesel_Brad
37
Mar 21, 2015 09:51 AM
benbuilder
Ford Truck Parts for Sale
Jan 5, 2015 02:26 PM
whalebus2112
19
Aug 4, 2012 06:46 PM
PROxac
Aug 29, 2010 11:28 AM
