Sponsored by: Real Truck
Running board connector adapter
Old Nov 15, 2016 | 09:07 PM
Kingranchguy01's Avatar
Kingranchguy01
I have a 2013 Ford F-250 king ranch 6.7 diesel. I just installed running boards with lights on it from a 2006 king ranch. My truck is prewired for running boards. Unfortunately the connector from the running boards doesn't match my prewired connector. I have gone to autozone and Ford dealership to buy an adapter but Ford said they don't make a adapter or the connector for a 2013 model. I would be fine just Hard wiring the new connector to the running boards but i don't know where to buy the correct connector since Ford or parts house doesn't carry it. Any thoughts of where I could buy 2 connectors? Thanks guys
Old Nov 16, 2016 | 04:49 AM
Just Strokin's Avatar
Just Strokin
Look through this link and see if you can find the connector.
http://www.fordservicecontent.com/pu...torcatalog.pdf
Old Nov 16, 2016 | 05:04 AM
Ron94150's Avatar
Ron94150
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
You can thank AZLugz for this. It is labeled as a speaker connector.
Old Nov 16, 2016 | 05:32 AM
AZLugz's Avatar
AZLugz
Actually thank the FTE family as I got the number from another post here but it worked good. You can look at my build thread in my sig for details on the connection.
Old Nov 16, 2016 | 06:16 AM
RightWingNutJob's Avatar
RightWingNutJob
FYI on the Amazon speaker connector. It works fine, but it's an "interior" connector and it doesn't have any sealing gaskets, so moisture/road salt will get inside of it. You will need to put liberal amounts of Di-Electric Grease on the pins to repel moisture and prevent corrosion.
When I built up my harness for the running board lights, I shrink-tubed the back of the connector to block moisture from entering, Once it was plugged into the OEM Ford connector, I wrapped the whole connection like a mummy with electrical tape.
Old Nov 16, 2016 | 12:39 PM
Trophy_23's Avatar
Trophy_23
Is this connector behind the wheel well? I have a 2007 lariat, and was going to have a look for it with the idea of adding my own version of running board lights. Thanks
Old Nov 16, 2016 | 12:46 PM
AZLugz's Avatar
AZLugz
No, mine was on the frame, outboard side at the back of the cab just forward of the cab mount.
Old Nov 16, 2016 | 12:52 PM
Trophy_23's Avatar
Trophy_23
Thanks, I'll have a look, though I wonder if they may have only been on crew cabs? Mine is Ex cab.
Old Nov 16, 2016 | 01:16 PM
AZLugz's Avatar
AZLugz
I think it is more based on the options on the truck, mine is a platinum and I think the other guys was a lariat, I know one guy that has an XL and said he did not have the plugs. Yours being a KR I would assume they are there. The plugs had caps on them on mine that had to be removed.
Old Nov 16, 2016 | 01:57 PM
Ron94150's Avatar
Ron94150
Mine is an xl and has them. It may have to do with model year as well, mine is a '16.
Old Nov 16, 2016 | 02:11 PM
Trophy_23's Avatar
Trophy_23
I just had a good look at my 07 Lariat and don't see the plug. As mentioned it is an ex cab that may make a difference.
smittybuilt
Jun 13, 2017 06:58 PM
cwolfe78
Jan 10, 2017 08:16 AM
Movingsolution
Mar 7, 2014 11:39 PM
Slowlearner
Ford Truck Parts for Sale
Dec 19, 2013 02:09 PM
King-bRanch
Apr 23, 2013 08:17 PM
