Sponsored by: Real Truck
Improving empty ride quality
Old Nov 19, 2016 | 07:45 AM
  #46
The Bone's Avatar
The Bone
I run about 10 pounds of air in the bags when I am unloaded which works with the shocks to cushion the ride. I bump that up to 60 pounds loaded with my trailer. I also run 80 pounds of air in the rear tires all the time. The only time I would consider adding weight to my truck is because of winter time for traction.
Old Nov 19, 2016 | 09:57 AM
  #47
FordBlueHeart's Avatar
FordBlueHeart
That's a lot of psi in those rear tires when unloaded. I guess if you vary from empty to loaded often, it doesn't make sense to reduce pressure when empty. I've read that some airbags need to have a certain amount of pressure in them even when unloaded.
I think the biggest variable in the subject of ride quality is our own idea of what rides good or better than someone else's idea.
My wife has fibromyalgia which causes pain through out her body and can be exacerbated with a bumpy ride or sometimes a smooth ride that might have a sudden jolt. The more car-like ride I can get out of my truck, the more likely we can use it more often rather than her vehicle. For me, it's all about being able to enjoy my wife's company while getting things done that require the truck.
Old Nov 21, 2016 | 08:21 AM
  #48
Log Hog Kust'em's Avatar
Log Hog Kust'em
All this talk about rough ride on a F250 has me confused. One of the reasons I bout the Ford was the ride. It rode A LOT better than my 2009 RAM! Much more like 1/2 ton. I got a good deal on airbags and on-board air compressor to help with hauling my 5th wheel (10,000#). The airbags hurt my empty ride (airlift tech support supported that this will happen) It is still better than my Ram 2500. Interesting note: the truck rides better empty with 10 psi in the bags than it does with 5 psi. Ford's F250 6.7 is a great hauling platform!
Old Nov 21, 2016 | 09:47 AM
  #49
89LX306's Avatar
89LX306
Originally Posted by phillips91
That's been my experience with every body style and brand I've driven.
Not my experience.
A friend of mine has a 2013 long wheel base crew cab F350 and he has the same rough ride as my 2012 does. He also had a short bed prior to this truck that did not ride near as rough.
Take a look at this video (I believe the truck in the video is a short bed). This is not my video, but this is the same bounce my truck and my buddies truck have, although the truck in the video is more pronounced. Mine shakes enough to shake the passenger seat and will shake your voice quite dramatically when you are talking just like in the video.
Old Nov 21, 2016 | 12:22 PM
  #50
redford's Avatar
redford
FTE Leadership Emeritus
Originally Posted by 89LX306
Not my experience.
That video is funny.
Almost makes you car sick?😁
Old Nov 21, 2016 | 12:25 PM
  #51
99f350sd's Avatar
99f350sd
Didn't read the whole thing so sorry but I do 50 or so psi front tires and 45 rear. Load E tires...rides good even with plow springs.
Old Nov 21, 2016 | 01:51 PM
  #52
don123's Avatar
don123
Plow package with 65 psi in front 80psi in rear and my CCLB rides like a Cadillac
Celtictexan
Feb 10, 2019 10:24 AM
42pilot
6.7L Power Stroke Diesel
Jan 19, 2018 10:14 AM
2009kr
Jul 8, 2016 11:17 AM
tony montana 42
Jun 20, 2016 11:25 AM
EZ-Ford
Jan 8, 2007 11:17 AM
