Sponsored by: Real Truck
Improving empty ride quality
Old Nov 17, 2016 | 05:02 AM
  #31
Pit Crew's Avatar
Pit Crew
Originally Posted by Garyl53
I added 4 - 60 lb tube sand bags from Home Depot to the rear of the bed. Appears to improve the ride considerably. Also have Bilstein 5100s.
I doubt its the sand bags, your truck doesn't even know they are back there. I think more like 800-1000 is what`s needed to get the ride he is after. And only gets better after that.
Old Nov 17, 2016 | 05:10 AM
  #32
redford's Avatar
redford
FTE Leadership Emeritus
I use 6 70lb bags in my bed in the winter, 420 lbs total.
It does change the ride, substantially. You don't need 800-1000 lbs. to feel the difference.
Old Nov 17, 2016 | 07:51 AM
  #33
89LX306's Avatar
89LX306
I have tried just about everything listed in this thread and my 2012 still rides like a buckboard. My 2002 short bed crew cab 4x4 rode MUCH smoother than this 2012. I have aftermarket front coils, Bilsteins, air bags, 37 inch tall tires and nothing has changed the ride for the better. The only thing that makes it better is when I put my camper shell on...read add weight over the rear.
Old Nov 17, 2016 | 09:40 AM
  #34
Norma stitz's Avatar
Norma stitz
Go to the farm store and get a "stall mat" they come in different thicknesses from heavy to unmanageable. This will add some weight while also providing lots of function in a rubber mat, still looks good and doesn't clutter the bed up with sand. Plus they are only like 40$. That's plus some bilstiens and I bet you have a better ride.
They also sell custom made bed mats on Amazon for pretty reasonable prices.
Old Nov 17, 2016 | 11:22 AM
  #35
Garyl53's Avatar
Garyl53
I should have also added that I run at 55 psi all around. It doesn't take much weight to stop the excessive bouncing experienced when empty. I agree that more weight would clearly improve the ride.
Old Nov 17, 2016 | 12:06 PM
  #36
stufarmer's Avatar
stufarmer
Look into Sulastic leaf Spring Shackles.
Old Nov 17, 2016 | 12:24 PM
  #37
timbo79's Avatar
timbo79
16 f250 super duty 4x4 ext cab long bed 6.2L, I added Bilstiens & a ARE topper weighing approx. 200# & air bags for 36' TT.
Ride has improved.
It is still a truck.
Old Nov 17, 2016 | 01:19 PM
  #38
mikereidjr's Avatar
mikereidjr
I have airlift 5000 ultimate bags on my truck, I really don't see how they have helped my ride empty-
Old Nov 17, 2016 | 02:18 PM
  #39
timbo79's Avatar
timbo79
In my case, the shocks & topper helped with the empty ride & the airbags "helped" with the ride pulling the 36' TT, most noticeable on the highway expansion joints, helped with the soft spot before springs really engaged maybe?
Don't really notice airbags without trailer(5psi).
Old Nov 17, 2016 | 09:41 PM
  #40
FordBlueHeart's Avatar
FordBlueHeart
Your 2002 didn't have 20" rims.
Old Nov 18, 2016 | 08:17 AM
  #41
89LX306's Avatar
89LX306
It also didn't have 37 inch tall tires. Even with the factory 265/75/16's that truck rode better than this truck does. When it was lifted with 35's it rode much better than this truck does.
Stock for stock the 2002 rode much better. Mod for mod the 2002 rode much better. I have no doubt I could put 17 inch wheels on the 2012 and it would still ride crappy unloaded.
Old Nov 18, 2016 | 11:11 AM
  #42
FordBlueHeart
Sounds like your 2012 is a POS. My 06 rides incredibly better than my 2000 did despite lousy worn out shocks. I added about 400 lbs of sand in the bed which stopped the leafsprings from hopping and bucking all over the place. My passenger side front shock is lacking the lower bushing it's so worn out.
What level of Carli Suspension leveling kit do you have?
Maybe you mentioned it previously, what pressure do you keep your tires at unloaded?
Old Nov 18, 2016 | 11:52 AM
  #43
89LX306's Avatar
89LX306
No...it isn't. But it rides rough...just like a lot of other long wheel base super duties. Like I said above, my camper shell stops the issue.
Old Nov 18, 2016 | 12:38 PM
  #44
82_F100_300Six's Avatar
82_F100_300Six
Ok now I'm confused. I thought the long beds rode better.
Old Nov 18, 2016 | 01:53 PM
  #45
phillips91's Avatar
phillips91
That's been my experience with every body style and brand I've driven.
