Sponsored by: Kumho
Steering help F150 2011
Old Nov 15, 2016 | 03:03 PM
tuckr2's Avatar
tuckr2
Couldn't find anything related. My f150 steering appears to be not as smooth as when originally purchased. Only 50k miles. Typically driving at higher speeds and making slight correction turns it appears to bind just slightly then when it does move the truck tends to over steer.
This is an intermittent issue and can be hard to replicate. Best noticeable at highway speeds as the change occurs more quickly. Doesn't show up once you into a turn but instead most noticeable when going from straight to slight turns.
No aftermarket changes since new. Happens with or without pulling loads.
Again from center of steering position. Help
Thanks
Old Nov 22, 2016 | 07:26 PM
Ford79's Avatar
Ford79
Check the universal joints in the steering shaft. I've seen them go bad and cause issues like you describe.
vlietracer64
2009 - 2014 F150
Sep 17, 2018 04:49 AM
garagegods
Jul 30, 2015 03:56 PM
Methodical_1
Feb 6, 2009 07:22 PM
