C4 trans shift kit install ?
Old Nov 12, 2016 | 04:44 PM
mauicruza's Avatar
mauicruza
I got a trans go shift kit for my 74 c4 trans. Instructions basically details which springs to swap, also a hole that needs to be enlarged on the separator plate with the supplied drill bit. It states nothing about having to remove the v/body from the case but I'm guessing you'll have to because the pic shows it off. My question is will i damage the gaskets when removing the vb? My local Napa store does not sell just those gaskets separately so if anyone knows a supplier that sells these gasket separately please lmk. Also any other advice in doing this kit is appreciated. Thanks
Old Nov 15, 2016 | 09:26 AM
Braggs's Avatar
Braggs
If you separate the valve body halves, you will likely need to replace the gasket (plus hours of scraping off old crusty gasket material). Ebay has them for $12 and under. Might look and see if you have a local transmission shop/store that sells parts. Pretty common in bigger cities.
http://www.ebay.com/sch/i.html?_from...asket&_sacat=0
Old Dec 4, 2016 | 04:31 PM
Bulldog187th's Avatar
Bulldog187th
you want it out if you drill because you dont want any metal shavings in that case.
TJVJR
1983 - 2012 Ranger & B-Series
Oct 22, 2015 09:11 AM
beeturbo
Jul 26, 2009 06:40 AM
ajm859830
Aug 7, 2006 01:37 PM
enduringexplorer
Oct 17, 2005 09:17 AM
enduringexplorer
Apr 11, 2005 06:43 PM
