Temp spiking + dropping immediately (long post please read)
Best Regards,
Jameson
If you aim an IR temperature gun at the engine, does it jump around too?
Engine cold, start engine with radiator cap off. Does a stream of coolant flow into the radiator neck from that cross over tube?
Has the water pump ever been replaced?
Best Regards,
Jameson
Grab the fan when cold, and try turning it for resistance. Also, check for wobble on the shaft. Check for the same after the engine has reached operating temp.
Had to warranty mine out because it was doing the same thing, and the engine would only cool off when accelerating. It was only 4 months old. It was a Murray. So far replacement has been optimal.
Also, check the condition of the lower radiator hose. Had similar problem. Hose was a year old, but was collapsing when hot. It was weak and spongy feeling and appeared to bulge when hot. It was a Master Pro. Swapped it for a new Gates hose.
Swapped that out and also stopped having temperature swings.
Remember, NEW doesn't mean quality is very good or better than what was installed previously.
Give us a run down on your fan clutch, it's operation and the condition of the lower radiator hose.
● Upper radiator hose 140°F
● Lower radiator hose 115°F
● Block where sender is located 160°F
These reading were taken after driving for half an hour. The whole trip my temperature gauge was jumping from 180°F to 240°F. the first reading I took was when my temp gauge was at 240°F, so the numbers that I wrote here are when my actual temp gauge was reading 240°F. This is what led me to believe in the beginning that it's a head gasket issue with combustion gases displacing the coolant and the temp gauge actually taking a reading of the hot exhaust gases but I could be way off on that and I hope I am. You know how it goes when you're dealing with these issues for so long you start to lose track what you thought it was in the beginning. This is why I came here because my head is so full of ideas of what this could be. I'm not here trying to make it anything other than a head gasket because if it is I'll start tearing it apart but I just don't know. The fact that it didn't start happening until after I pulled the plenum off to replace the fuel injectors is what is keeping me from thinking it's a head gasket because my head gasket can't blow if the truck is sitting in the garage. Thank you for all the advice and ideas , everything hekps, any suggestion,anything. I can't figure out how to post a video here but if anybody has any suggestions of how to do that please let me know and I'll post a video.
Best Regards,
Jameson
But I have never had the issue myself. Definitely check the fan clutch.
Keep in mind that the PCM uses one temp sensor and the gauges use another.
Guys he's seen the same results with two independent gauges now, so it's not a gauge issue. I think there's no other reasonable hypothesis then that gases, combustion gasses or steam are displacing coolant. Things to check...
But first, please next time you get into the thermostat drill a small hole in it. Just a tiny whole in the area around the valve. This helps air escape from under the valve preventing an air pocket that could disrupt the operation of the valve. That said I don't think that's your issue cause it's been so consistent throughout all your parts changes.
1. This may be very rudimentary but the cooling system is under pressure correct? I see no mention of testing or replacing the radiator cap. Something as simple as a bad radiator cap can cause these exact symptoms. Usually there's also a loss of coolant but not always. The radiator cap is a pressure relief valve, and they do fail. You must maintain enough pressure in the coolant when hot to prevent the hot spots inside the block from boiling. If there isn't enough pressure the coolant in the block/heads can boil and create a steam pocket. Usually with a warn radiator cap you lose coolant slowly as well as usually little bits of steam make there way all the way out, but not always. There are testers for radiator caps, but it's really simple to check yourself without the tester, I do it by routine just about every time I open the hood. When it's warmed up try and squeeze the upper radiator hose, you should not be able to squeeze it much at all. If you do it often you'll get a good feel for the temp and hardness and be able to check most of your cooling system with just a squeeze.
All that said even if it looks good, as much as this is costing you, it may be worth while to go grab yourself like a 20lb cap. If increasing the pressure helps at least you learn something and have made progress.
2. Sadly you may have an issue where combustion gasses are leaking into the coolant. BUT don't start pulling it apart, there is a rather easy and cost effective tester to find out. But first there's other clues, mainly gasses in the radiator. If combustion gasses are making there way into the coolant they will make there way to the radiator and this can be noticed. It will appear as if it's always burping air, but in minor leaks this can be hard to notice. So there are testers like this https://www.amazon.com/Lisle-75500-C.../dp/B0007ZDRUI What they do is use a chemical to test for combustion gasses in any gasses that are in the radiator. You put the chemical in the tube like bong water and draw the gasses from the radiator through the chemical. It will change color if there are combustion gasses present.
3. The water pump was mentioned, while no specific reason to suspect the pump. It's easy enough to at least test to find out that it hasn't rotted away or fallen apart on the inside. Remove the radiator cap and rev the engine, the coolant level should rise.
That tester BruteFord talked about is awesome and it does work. When I was in the wrenching world I used one all the time.
thank you so much for your long responses to my issue. I'm sorry that my wording is all broken up but I used the speak to text. I did try to drill a hole in the thermostat a few days ago and it made it worse. There was no coming down from the temperature spike it would just sit there at 230°F until I turned the vehicle off and back on again. my upper radiator hose is definitely firm everytime I turn the vehicle off. I did purchase a new 13 pound radiator cap but with the same result. I will purchase a 20 pound cap tomorrow and let you know how that goes. I also just ordered the tester to see if the combustion gases are entering the cooling system and I'll follow up with you and let you know how that goes. To answer your question plowboy the temperature goes up and down wether im moving or sitting still. One thing that may be coincidence that I've noticed is that the temp doesn't seem to spike nearly as bad when my heater is OFF. Probably coincidence. You've given me some things to check so I'll do that tomorrow and get back to you. Thank you so much.
Sorry for not getting back to you yesterday but I've been crazy busy. This is going to sound pretty crazy and a lot of this may just be coincidence. Monday night i decided to replace my EGR tube, which I forgot to tell you guys was broken. I had ordered it about a month ago but just hadn't had time to replace it yet. While replacing my EGR tube I noticed that the smog pump was disconnected so I obviously reconnected it. The following morning on my way to the job site, which was about 30 mile trip, I didnt use the heat in my cab and left the **** in the "off" position and I had no issue with the temperature spiking. On my way back home from the job site I left the heat off until I got about two miles from my house then I turned it on "Hi Defrost". Within about a minute-and-a-half my temperature skyrocketed. So today I did the same thing but I drove even further with the same results. I haven't pressure test of the system yet just because I don't have the right tools and I haven't had the time but I will definitely do that this week. I just wanted to let you guys know where I'm at. Could be coincidence I don't know. I will continue to keep you updated. Thank you
1. You have high electrical resistance in either the sender, or the wire, or somewhere else.
2. Where is the ground for the digital temperature gauge? If it's not a clean, shiny "Block" ground, it's gonna read all over the place.
What it tells me so far is that when you increase electrical load, the temp gauge(s) spike accordingly.
I had a similar problem. The sender on my 300 is located in the Cast iron block. I chased an over temp engine for years...turns out, the rust in the threads wad throwing my temp gauge off.
I also had a digital temperature gauge. The ground was wired to some ground, cant remember where. But when I increased electrical load, it would start to spike, along with the dummy dash gauge. Well, after finally moving the ground to the block and cleaning the threads of the block, (7 years), I finally got my exact temp reading and no more spikes.
Pull the sender from the intake manifold, clean the threads good on both the sender and the intake. Make sure your ground for the digital gauge is bolted to a good block ground. Shiny and bright.
One thing many people forget is that your AC pump turns on when in defrost mode to help dry the air. This will heat the AC condenser.
If so, and if you think maybe the two are related disable your AC by unplugging the AC clutch. It's a two wire plug on the top front of the AC pump.
