Brake wiring.
Old Nov 12, 2016 | 09:38 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Brake wiring.
Fellow RVer is coming by to compare my brake wiring at the hub to his. He blew a tire. 2010 Mountaineer 5th wheel 324 RLQ (Yes, we have the same one)
I just looked at mine. I have 2 white wires dropping out of the floor to drive side axel. (side the tire blew) I can't see a difference between the 2 wires. No markings.
They drop to the cross over wires to the passenger side, which one is a brown color, the other white.
So, How do we figure out which white wire goes to the brown wire and also the other white wire to actual brake?
wire 1 = white to brown and white
white 2 = to white
Thanks
Old Nov 12, 2016 | 09:39 AM
amdriven2liv
Sorry, needed to post this in the other forum, sorry.
Old Nov 14, 2016 | 05:06 AM
senix's Avatar
senix
wonder if there is any slack to where you can either give a slight tug and tell or probably better yet put some power to one at that connection on the drivers side and check the power at the door side and see which one is energized.
Old Nov 14, 2016 | 07:43 AM
amdriven2liv
There is a good foot of wire that we could pull out of the plastic loom.
He is going to check for power coming down, then go from there. He is going to need to go deeper. When we looked at his trailer, the wires going into the brakes were sheered off to close to get a good splice I'm afraid.
I had suggested plugging in his pig tail, and have me or someone power the brakes. With all those wires exposed, he could have blown a fuse also. We will see.
Thanks.
amdriven2liv
All Things Towing
15
Jul 7, 2017 10:45 AM
goatsauce
2009 - 2014 F150
Jun 25, 2017 01:39 PM
V10man
All Things Towing
Nov 22, 2007 10:52 AM
Sycostang67
All Things Towing
Mar 12, 2005 12:56 PM
2000F250SD
Sep 4, 2004 08:54 AM
