I need to tow a trailer tomorrow just a light landscape trailer maybe 2800 pounds and I will load it with orchard grass bales so maybe 5-7k pounds loaded.
i only have 600 miles on the truck is it ok to tow or do I need to wait 1000 miles is this an actual thing people do or more of a personal preference?
The reason for the break-in period is not so much for the engine but for the drive line. Specifically the rear differential. The concern is heating up the rear end before the metal has had an opportunity to properly temper via normal to light use. Pulling a bunch of weight too quickly will create a lot of heat in the rear end. If you take it easy and give the gears a chance to cool the metals will be happier.
By the way, has anyone else noticed the foil-wrapped insulated brake line that passes behind the rear differential? If that's not an indication of the heat that can be generated, I don't know what is.
I guess I'll see it when I get a truck. This immediately triggers the question "is it waterproof?" Trapped winter moisture might do more harm to the line than heat from the differential. The worst rust points on a vehicle occur when absorbent materials are affixed to metal surfaces. For several years the adhesive used to bond the side panels of the P/U box were like a foam rubber sponge. The box would rust pre-maturaly right at the seam. The F-150 even had a call back for correction.
Hmmm... I've never heard of the metal brake lines going bad. At least not on newer vehicles that haven't been sitting out in the pasture for a couple of decades. But I don't live in the salty East either. I find it interesting that Ford felt the need to insulate them from heat. My 2011 had an aluminum differential cover with fins on it to help dissipate heat but those covers went away pretty quickly in 2012 I think. It shows two things. Enough heat is generated to affect braking and second, I'm glad that Ford pays this level of attention to engineering detail.
All this speaks to the importance of a break-in period for the ring and pinion. I don't understand the metallurgy but find it interesting. Now I'm going to start checking the diff case temperature when I'm towing in addition to the brakes and tire temps.
thanks
In todays world of being able to measure, build and mass produce to clearances that were unheard of at one time engine break in a all but a mute point. The rest of the drive line along with the engine with be will broken in within a 500 mi timeframe.
Now EpicCowlick has a legit point. I have used modified Ford Dana 60's in my off road Jeeps, I get them from a company https://www.dynatrac.com and they recommend a 500 mi break-in, which is to say in HIGH TECH engineering lingo...don't let the pumpkin get hotter than you can put your hand on till you get 500 mi on it.
I would say this is sage advice for the longevity of that axle set. If you get out there smoke it with less than 500 mi its not likely to bite you in the butt for several years and miles down the road.
As you have 600 mi on your rig, then you are good and for it!
Except I don't think the differential is why the line is wrapped. I think it is to protect the fluid from getting too hot when the truck is regenerating. I had already taken a few pics of the undersides of my dually, so take a look:
Notice how both the brake line and e-brake cable going to the right rear wheel are both only shielded on the right side of the differential, and continue on well past the differential...yet the left side of the brake line and e-brake cable are not shielded at all, despite sitting right on top of the differential?
I guess the way to truly tell if I'm right would be to look at a gas F-350 dually, which will be hard to find, since it is the only gas truck to share the M275 / M300 (My truck is an M300 in the pic).
I'd bet a gas 250 or 350 does not have that shielding. The exhaust during a regen radiates 1200F heat. The diff gets nowhere near that hot.
so i had the day off today so last night we drove to the bay area for dinner and i volunteered to drive lol because i find any excuse to drive now a days. so by the time we got home i had about 980 miles on the truck and now i won't have any second thoughts when i will be towing and will take a bigger trailer and get extra bales to cover me thru the winter.
Yeah, it has to be the regen that the shielding is for. I only looked under from the backside once and immediately thought differential because that it was it was closest to.
I noticed the brake line wrap last week. I like the idea and the attention to detail.
But aren't brake lines made out of aluminum? They shouldn't rust.
Had the aluminum diff cover on my 08, I think that was the first year of it. They are definitely concerned about the heat that is generated there.
i'm not sure if I've seen any of the other manufacturers do anything more than put a stamped metal cover on.
Ford and Dana Corp have given us a good product. I am surprised that the cover is not more integrated into the strength profile of the axle set, would love to talk with the engineers on that.
There is a LOT of meat in that axle set and it holds a lot of oil and that is there approach to keeping those things cool, lots of beef and lots of oil. I have installed those axle sets by myself and trust me it is a hellva of job.
I have had a lot of experience with galvanized metal lines going bad but I also have a tendency to keep vehicles longer than most plus live in the rust belt. Rust damage usually starts where the line is in contact with the frame and especially at the clips where moisture can be trapped. About once every three months I push the brake pedal all the way to the floor and hold it for 1 minute as a hydrostatic test in the driveway. Better to break the brakes there than approaching a line of stopped vehicles. Just last week I had to replace the transmission cooler lines from the transmission to the radiator because the stretch over the crossmember and closest to the exhaust manifold was completely rotted away and covered with dark brown rust scales. Hate the smell of MerconV running down my arm and in my hair. Please bring me a new truck so I can start all over again.
