Third Brake Light
Old Nov 10, 2016 | 06:42 PM
Glenn54's Avatar
Glenn54
Third Brake Light
I took the third brake light off my truck, primarily because I'm opening my door and leaving it open working on my door latch, etc. I discovered the middle light area had melted a little of the plastic on the interior of the light assembly. After looking at it closer, it appears a screw from inside the cab was over an inch too long and "likely" shorted it out. I ordered a new (aftermarket) light and have that installed.
I thought I saw where someone on this site was trying to find a OEM third brake light. I think this one is probably salvageable. If anyone wants it, it is yours for the cost of shipping. I will do my best to ship within a week.
Old Nov 11, 2016 | 01:58 AM
My4Fordtrucks's Avatar
My4Fordtrucks
So you now have a hole in your cab? Why not just pull the bulbs?
Old Nov 11, 2016 | 09:05 AM
Glenn54's Avatar
Glenn54
No sir. As mentioned, I purchased a new aftermarket light and have that installed.
Old Nov 16, 2016 | 01:10 PM
Glenn54's Avatar
Glenn54
No interest? If not, I will trash it.
Old Nov 16, 2016 | 07:47 PM
BeholdenZippy's Avatar
BeholdenZippy
If the seal on it is good and it's not leaking water, you could try putting it on Craigslist. I had some trouble finding a good used lens when I chased a water leak problem so I'm sure other may need it. Just out of curiosity, did you out in an led third brake light?
Old Nov 16, 2016 | 08:00 PM
Glenn54's Avatar
Glenn54
I may try Craigslist and see what happens. I was really just wanting to give it away to someone that needs one. The seal appears to be ok. Not sure what your question is on the LED light I replace it with. Are you asking what it cost? If yes, I paid $45.89 at Amazon. I think it looks good. Works good too.
Old Nov 16, 2016 | 08:10 PM
BeholdenZippy
I was going to ask if you had torque converter lock up issues if you had a 4 speed automatic transmission. I thought about getting an led when my lens went bad but decided against it.
Old Nov 16, 2016 | 08:33 PM
Glenn54's Avatar
Glenn54
The transmission seems to working fine, so far. I haven't put many miles on it since I bought it though.
Old Nov 16, 2016 | 08:36 PM
BeholdenZippy
alright. Hypothetically the bias voltage should be able to find ground through the other bulbs if they are standard bulbs.
MustangGT221
Aug 15, 2005 05:47 PM
MemOrex
Jan 4, 2005 10:15 PM
parks911
Jan 19, 2004 02:17 AM
CZorn25
1983 - 2012 Ranger & B-Series
Jan 22, 2003 10:55 PM
i_got_2_golf
Aug 5, 2002 12:49 PM
