100,000
Old Nov 10, 2016 | 10:50 AM
gdiehl's Avatar
gdiehl
Im coming up on 100,000 miles on my 2013. Ive looked everywhere and can't find anything specific regarding 100,000 mile maintenance. Is there a list or something out there that specifies what should be done to the truck at 100,000 to increase longevity?
Old Nov 10, 2016 | 12:07 PM
ssunit1's Avatar
ssunit1
Just a check of the owners manual will give all the recommended maintenance intervals.
Old Nov 10, 2016 | 03:27 PM
Painted Horse's Avatar
Painted Horse
As stated, Look at the manual But off the top of my head. Coolant is recommended for 105,000 under normal duty
From my previous 2011 truck, At 100,000 my batteries had been replaced, Brakes had been replaced, replaced my front Hubs at 105,000 and I flushed both my coolant and tranny. I also was getting the death wobble for the second time and replaced the front steering stabilizer again. If this gives you any ideas of what might be worn out.
Old Nov 10, 2016 | 06:44 PM
Dakster's Avatar
Dakster
How many miles on your 2015 and what have you done on it so far Jon? Just so we can get an idea on how the 2015 is doing? I only have 14k on mine...
Old Nov 11, 2016 | 06:48 AM
ruschejj's Avatar
ruschejj
I'll but in since I just rolled 125,000 on my 2015.
Brake pads, didn't touch rotors.
Radiator leaks, has been for a few months, when I fix it I will get the coolant flush done.
Rear seat heat shorts out because the parking brake mechanism keeps chewing up the wire bundle.
My transmission seems to be getting a bit rough so I may need to get it flushed out.
Old Nov 11, 2016 | 10:34 AM
Painted Horse
DAK, I've got 55,000 on it now.
Replaced the tires for winter snow and discovered that my front pads were paper thin, So we turned rotors and replaced pads.
I had to fix a tailgate that got a dent from GN dump trailer jumping off the ball and had to replace Tonneau cover that the trailer crushed. But that was operator error and not Fords problem.
My front LED bar stopped working, I thought it was a bad connection on that short little lead wire coming thru the firewall. But it turned out some battery acid had gotten on and ruined the relay that the Upfitter switch turned on to allow battery power directly to the lights. I moved the relay farther away from the battery.
My Lariat leather seat is showing wear from my constant getting in and out of the truck. A seat cover may be in the cards.
Other than the above, It's just been oil changes, check the coolant, and add Fuel and DEF.
My command center is showing trailer mileage at about 25,000 miles so almost half of my total mileage. With that kind of work, I'll probably flush tranny and coolant at 75,000 miles.
Old Nov 11, 2016 | 11:46 AM
senix's Avatar
senix
At 100K I would do both differentials, tranny and coolant flush and check those brakes if you have not done so already.
Plus the transfer case.
Old Nov 12, 2016 | 12:16 PM
ssunit1's Avatar
ssunit1
Fords on line maint schedule for any year / vehicle. Here's the one for 2013.
the last major hump for your F250 was at 90K.
https://owner.ford.com/tools/account/maintenance/maintenance-schedule.html#/details
Old Nov 12, 2016 | 12:21 PM
ssunit1's Avatar
ssunit1
Sorry about the bad link above. I'm not a 13yr old kid that can do this stuff in my sleep.
I just goggled 2013 f 250 maintenance schedule and got fords maintenance site
Old Nov 13, 2016 | 09:15 PM
gdiehl's Avatar
gdiehl
Thanks for all the responses guys. Scott, the link you posted, after opening it I realized I had already found that but just forgot about it haha.
Marching Ant
6.7L Power Stroke Diesel
Apr 16, 2015 07:24 PM
KC8QVO
Oct 9, 2012 10:00 AM
darren32
17
Dec 10, 2011 03:34 AM
1saxman
2004 - 2008 F150
Jun 19, 2010 01:14 PM
Big-Red-Lariat
2004 - 2008 F150
Aug 16, 2009 04:17 PM
