302 Problem
Old Aug 24, 2003 | 02:20 PM
big_black_4x4's Avatar
big_black_4x4
302 Problem
I have a 1988 302 in a F-250 4x4, its a 5 spd. When i shift from one gear to another my RPM's jump up. I was told it was the Idle Air Controll Motor. Is this the correct name for the electric motor located right by the throttle body ? Please Help
Old Aug 24, 2003 | 07:03 PM
lvmoose007's Avatar
lvmoose007
302 Problem
yes.,
Old Aug 25, 2003 | 10:54 AM
fishin1976's Avatar
fishin1976
302 Problem
How low in the RPM range are you shifting? If you shift below 1000 rpm the engine may think it is dying, and think it is at idle and try to compensate for the increased load (shifting).
If it is doing this at highway speeds or cruising speeds, I would check that your return spring for the throttle is strong enough or that the accelerator cable has not streched or binding. This would make your throttle blades not close when you let off the gas and let the engine rev higher between shifts.
Daltongang
Oct 29, 2013 05:53 PM
aprphil
1978 - 1996 Big Bronco
Jan 22, 2008 09:22 PM
tsi9973
Apr 27, 2006 05:43 PM
JPontius
May 10, 2005 07:52 PM
jb85302
Sep 8, 2001 12:41 AM
