Steering Wheels
Old Aug 24, 2003 | 10:50 AM
Custom 1975's Avatar
Custom 1975
Steering Wheels
Does anyone know a good source for OEM type Steering wheels (Besides a Dealer). I need to replace mine on my 1975 F-250 it is cracked and nasty, missing horn button etc. I want to stick with the original but don't want to invest the kind of money that my local ford dealer wants for the OEM. (no luck at our junk yards around here either).
Also, while driving my truck over rough terain, I get rattling noise that comes from the steering wheel (column) like it is loose. However it is not loose. Anyone experienced this before?
Thanks
Old Aug 24, 2003 | 12:06 PM
jor's Avatar
jor
Steering Wheels
Just keep checking eBay. They turn up once in awhile.
jor
Old Aug 24, 2003 | 04:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
Steering Wheels
Check the classifieds here for columns and wheels also. Sounds like you could use a complete column with wheel.
Old Aug 24, 2003 | 05:48 PM
Henry_the_Ford's Avatar
Henry_the_Ford
Steering Wheels
www.dennis-carpenter.com has em. They are made from original ford machines....I also found one in the junk yard in really good shape.
Old Aug 24, 2003 | 08:24 PM
76supercab2's Avatar
76supercab2
Steering Wheels
The way the pre 77 wheels are made they just crack. Plastic over a steel frame, when the wheel gets hot the steel expands and pop, there goes the plastic. The Eastwood company has a repair kit for these types of stearing wheels. Check their web site.
Old Aug 25, 2003 | 12:58 PM
GeneStoner's Avatar
GeneStoner
Steering Wheels
Try here:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2428689839
Old Aug 25, 2003 | 01:05 PM
73Custom's Avatar
73Custom
Steering Wheels
Another option would be a wheel from a 80-86 xlt. They are smaller diameter and have a padded grip (instead of hard plastic) and still appear stock. Just a thought.
Marty
Old Aug 25, 2003 | 09:11 PM
stephenw's Avatar
stephenw
Steering Wheels
Marty,
Do you know if these are a "bolt-on" to the earlier steering columns? Since updating the power steering I would love to get a smaller wheel, but want to maintain the Ford integrity.
Thanks, Steve
Old Aug 26, 2003 | 11:27 AM
Ken2600's Avatar
Ken2600
Steering Wheels
When I tried to put a 78 wheel on my 77, it bolted up fine and looked good but the turn signal cancelling cam doesn't work the same way. I tried to rig it to make it work but ended up breaking my cam.
I was trying a 78 Bronco wheel (automatic) on my 77 F150 (4 speed). Also the trim in the back of the wheel (where it meets the column) is slightly different in diameter between the years. It wasn't noticeable though.
I'm going to just get a Grant steering wheel to fix all my problems. I did some research on their website and found an install kit for their wheels that looks like it should work fine with my turn signal cam.
