HELP runs rough & P1361 code???
Old Apr 2, 2007 | 06:36 PM
racingtom's Avatar
racingtom
HELP runs rough & P1316 code???
On sat. morning I drove appx. 1/2 mi. parked, came out 5 min. later and started my 2001 F350 SD Diesel W/75,000 mi. and it was running rough and the SES light was on. I changed fuel filt. in the fall and maintain it well.
Pulled the code with my OTC Genisys and came up with P1316 Ignition Diagnostic Monitor Codes Detected.
My Alldata dosen't go to 2001 and I have no other info for this truck. I'm thinking I've got a injector gone bad.
Any one have any exp. with this that can guide me??
TIA
Tommy
Old Apr 2, 2007 | 06:51 PM
Pocket's Avatar
Pocket
I saw your first post in the Superduty section and answered in there if you would like to check.
Old Apr 2, 2007 | 06:55 PM
racingtom's Avatar
racingtom
Cool sorry for the double post I diden't realize there was a 7.3 PSD forum and posted there first.
Old Apr 2, 2007 | 06:58 PM
Uzumati's Avatar
Uzumati
that should probably be a 1316 code (IDM codes stored). Which could be anything from a contribution balance fault to a high/low open on one of the injectors. If you can do a BUZZ, KOEO and KOER with the Genisys it should return the IDM codes if it is capable of reading the powerstroke specific codes.
Old Apr 2, 2007 | 07:12 PM
racingtom's Avatar
racingtom
Yes 1316 sorry for the typo I'll check tommorrow if I can do a BUZZ test.
Thank's for the replies.
Tommy
Old Apr 2, 2007 | 08:22 PM
clintbonnie's Avatar
clintbonnie
Mine did the exact same thing about two months.. It turned out to be the under the valve cover 9 pin connector was just loose..by almost a 1/4" gap.. Reset connector and made a shim to slip under the plastic locking tabs and it was fixed.. Removed the other valve cover and that connector was just about the same but still making contact.. Bad design..
here is a pic what I found.. loose.. (you can check it will a ohm meter before you pull the cover...)
<a href="http://photobucket.com" target="_blank"><img src="http://i27.photobucket.com/albums/c178/clintbonnie/100_2110.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Old Apr 2, 2007 | 08:58 PM
racingtom's Avatar
racingtom
Thank's for the pic Clint now I have a better idea what's going on in there.
I'll take that over injectors any day.
wreedZ71
2004 - 2008 F150
15
May 14, 2009 07:33 AM
pdx02
Jan 23, 2008 12:51 PM
LostMayhem
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 9, 2008 12:17 AM
Imdok
Oct 11, 2007 01:11 PM
exdriver
Feb 2, 2007 06:53 PM
