Sponsored by: Real Truck
Ghost in the machine - electrical problem.
Old Nov 5, 2016 | 08:50 PM
bonshates's Avatar
bonshates
5th Gear
Unhappy Ghost in the machine - electrical problem.
Greetings,
I have a 2003 F250 Lariat 6.0L Crew Cab. My wipers, radio and power windows don't work. I have painstakingly checked every one of the fuses to see if there was one or more blown. All were OK.
I removed the fuse panel under the dash and have disassembled it to look for obvious clues, burnt wires/heat damage etc. but everything looks fine. Have pushed all of the fuses in to make sure they were seated properly. No joy.
I recently replaced one of the back windows in my truck and had to detach the rear dome light and I remember one of the wires sparking.
Any suggestions on where to start diagnosing this problem?
Many, many thanks in advance.
Old Nov 6, 2016 | 06:08 AM
seville009's Avatar
seville009
Does the dome light still work after the sparking?
Old Nov 6, 2016 | 07:45 AM
Sam I Am's Avatar
Sam I Am
Your truck's owner's manual.
Since you never mentioned the fuse box under the hood it sounds like you don't know to check there for the fuses that feed the under dash fuse box.
"Checking every fuse" is a waste of time and effort. You need to check the specific fuses, relays, wiring, and circuit breakers that pertain to the circuit(s) that you are working on.
Old Nov 6, 2016 | 09:43 AM
bonshates's Avatar
bonshates
5th Gear
The dome light has 3 bulbs in it. The center bulb, for an open door, works but the two other don't.
Old Nov 6, 2016 | 06:39 PM
ligito's Avatar
ligito
Sounds like a blown fuse.
Old Nov 9, 2016 | 07:53 PM
bonshates's Avatar
bonshates
5th Gear
Yes indeed it was a blown fuse. I was confused by the fact that the windows and wipers stopped working at the same time.
Old Nov 9, 2016 | 11:55 PM
ghulands's Avatar
ghulands
I had that same issue. Found the fuse by going and checking each one as the owners manual didn't really give a good idea of which one it would be. Found it, looked up it's label in the manual. "Instrument cluster". Worst. Label. Ever.
Old Dec 2, 2020 | 03:32 AM
nortwoods cook's Avatar
nortwoods cook
Dimmer switch is only 4 wires?
Dimmer switch is only 4 wires? Van someone tell me why my 2004 navi has 6. Lol
Old Dec 2, 2020 | 04:28 AM
Tedster9's Avatar
Tedster9
Welcome to FTE!
No idea. None of my Bus - iness.
f350rebel7788
40
Sep 18, 2011 05:46 AM
Neutron
Nov 28, 2005 11:09 PM
bartonl
Electrical Systems/Wiring
May 9, 2005 12:25 PM
winstoningram
Apr 19, 2004 08:16 PM
axlrose
Nov 11, 2003 02:57 PM
