headlight alignment
Old Aug 24, 2003 | 01:35 AM
Tedrow's Avatar
Tedrow
headlight alignment
Does any one know how to re align the front head lights on a 99 Ranger?
Old Aug 24, 2003 | 01:53 AM
FoxRider934's Avatar
FoxRider934
headlight alignment
I wouldn't try to do this myself, I would have it done by a professional
Old Aug 24, 2003 | 01:57 AM
rangerbrown's Avatar
rangerbrown
headlight alignment
they say the best way is to drive up to a wall and put a pice of tape where the light is then back the truck 25 feet then pont the head lame 3" below the first mark or tape then you are set. i may be wrong but you will have to to try. i did mine this way but they were off just a little but that can be fine tuned i had to do mine after installing a new set of lamps i went with some cristal clear ones hope that helps
Old Aug 24, 2003 | 02:00 AM
rangerbrown
headlight alignment
FoxRider934 is right, that would be the best way to be safe. Do it my way if you are only confident that you can.
Old Aug 24, 2003 | 02:21 AM
FoxRider934
headlight alignment
Yeah bcuz one of my friends tried to adjust his lights, and it was so far off it looked like it was cross eyed. It was funny. If your confident, do it yourself, but if you have any doubts take it somewhere to have it done.
Old Aug 24, 2003 | 11:16 PM
Tedrow's Avatar
Tedrow
headlight alignment
yeah I can do it myself but I've never seen fastiners like the ones on the headlamps, do you need a special tool or is there some techique I'm not clued into
Old Aug 24, 2003 | 11:27 PM
rangerbrown
headlight alignment
use a 1/4 inch socket drive with a 3 to 6 mm socket on it i am not sure what size
Old Aug 24, 2003 | 11:40 PM
Mike W's Avatar
Mike W
headlight alignment
I had headlamps adjusted by a "pro" once, only once. They were so low, it was unbelievable. I just park next to the garage door, make an adjustment and test drive to see how they look.
Davidjoe
Large Truck
Jan 7, 2016 11:31 PM
nikmish
20
Dec 3, 2014 07:21 AM
Rich8483
2004 - 2008 F150
Dec 2, 2014 08:13 AM
Gene Horr
Oct 3, 2014 12:41 PM
A/Ox4
N. California Chapter
Sep 2, 2014 04:22 AM
