I answered my own questions.
1. Yes
2. BSM = BdyCM in the features tab for some entries. It's all in the "726-xx-xx" range.
Duh. Never mind!
Original questions:
In the Forscan spreadsheet "features" tab, there is "BdyCM as built" and I've backed up the corresponding "BdyCM Module configuration (As-BUILT format)" & then used Forscan to eliminate double horn honk and enable Bambi mode. Awesome. Thanks so much for this valuable tool!
Question: Other MODULES are listed in the features tab, but don't explicitly include "as built". But I should load, backup, edit, write, and save "modded" the As-Built module, correct?
Question: Why don't I don't see the BCM module in my list of modules, listed for the Power Point Timeout 4 Hours feature?
thank you in advance.
Reason: duh....
just an FYI
This:
<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->BCM726-39-01xxxx x1xx xxxx**** xxxx xxxxReplace the **** with 3870. Allows power points to remain powered for 4 hours after the vehicle is shut down. After four hours the power points will timeout and stop supplying voltage to plugged in devices. This feature has had multiple confirmations but also failed on other trucks. Differences are unknown.didn't work for me. The usb powerpoints under the console used to stay on for 15 min or so; I reset to "3870" per example, now they go off immediately. Original value was 1194.
Hello I am new to the forum and not sure if I'm posting this correctly but wanted to say thanks for the spreadsheet. I have done several changes on forscan so far and love it. I have a 17 f250 6.7 and wanted to add some input on a code I found on the f150 forum. IPC 720-01-02 change to code is xxxx x2xx which disables seatbelt chime on startup! I entered code and it works for me but there isn't a red seatbelt icon on cluster anymore when not buckled. Wanted to run this by some of you who have possibly done this to see if there are any airbags or any other safety features that will be sacrificed with this change. Thanks
No, it won't effect anything else. The seatbelt light does not light up on my dash either (good!)
RE: Bambi mode. Everyone should be aware that running fog lights with high beams is against the law in most if not all states. Several F-150 owners have had their state inspection fail for this. You could be ticketed, if a policeman notices and isn't too busy with other calls.
That’s why it doesn’t come that way from the factory because of federal and local law. Bypassing this has been done for years electrically. Now there is a software change that does it.
I’m sure then it was done electrically, there were those that failed to change it back and did not pass inspection also.
I just have my fogs off when I go in for inspection. Never an issue. But yeah, very easy to change back with Forscan before inspection if you're worried about it.
No inspections were I am or where I will retire. I’ll be making this change in my son in laws f250 and f350 farm vehicles. Some if his friends are asking for the same change. Lots of deer and antelope near the farms.
Police don’t bother to pull over the jerks who put blinding xenon or LED lights in halogen enclosures, nor do they stop folks who run LED light bars on the roads. I think running stock fog lights with high beams (which are dimmed anyway when traffic approaches) is the least of the issue. Inspection stations rarely checking lighting for legality, just if they work or not. I left my fogs on and it went through inspection without a problem.
has anyone been able to change the heated seat bias? IE - the bottom of my seat gets way warmer than the seat back and imo defeats the purpose of a heated seat. any way to change this?
I think I've asked before but didnt get an answer so will try again. For those using the Lincoln theme, is there a way to have the ford logo at startup rather than the lincoln logo?
