Locating Dowel for ZF 5s-42 to 7.3L IDI non turbo
Looking for the locating dowels for a ZF 5S-42 transmission to the block of a 7.3L diesel. It appears that there are two and am curious if there is a source besides the dealer.
Also need two bolts for the adapter plate to the block which are behind the flywheel. Does anyone know the size of these bolts? McMaster is a great source yet I need to know the size of these two bolts.
Any help and info is always appreciated. Thank you in advance.
Go to harbor freight and buy a cheap set of calipers, and a thread gage or a tap set. You can measure the depth and diameter of the dowel pin holes, then order those from McMaster. Measure the thread diameter with the calipers, and the thread pitch with the gage to tell you what size bolt you need. Or, thread the taps in until you find one that fits. It's size will be marked on the side of the shank.
Additionally, diesels use 1/2 and not 7/16. Bear with my ignorance but I do not understand. Would you be so kind as to explain.
Thank you.
Thank you.
bishop0179
03-29-2009 02:09 PM
51PanelMan
04-24-2005 06:52 PM
