6.6 Engine Parts
Old Nov 3, 2016 | 08:57 AM
Thunderhorn's Avatar
Thunderhorn
6.6 Engine Parts
Got the 400 to the machinist. then got the list back yesterday.
-Block needs to be decked and trued, also honed/bored
-bores are 30 over and need to be cleaned up to 40 over
- rockers are good
- cam is pitted and flatened,
- crank is 10 under and needs to be cleaned up another 10
- pistons have lots of scratches (replacing them anyway)
- rods need resizing and threads fixed (basically need to replace them too)
- heads mag fine but need at least a valve job, likely new seats
So essentially right now i need to:
- decide on pistons,
- rods
- cam (+lifters)
then i can get these items to my machinist and he can clean up the block to accommodate them.
Problem is, i am having alot of trouble finding any good info or variety of choices for pistons and rods. I talked to tmeyer briefly but i didn't feel like he was interested in explaining anything to me. I am interested in the 400 engine kit they sell but i was hoping to be able to 'shop around' a bit before making any decisions even though i will probably go with something from tmeyer in the end. I wonder if there is anywhere else to get these parts.
Anyone on here built one of these themselves and got any helpfull tips?
Old Nov 6, 2016 | 11:10 AM
beartracks's Avatar
beartracks
From your description I'm not sure a .010 overbore will be enough. Also not too sure about going past .010 on the crank.
Old Nov 12, 2016 | 12:51 PM
SDDL-UP's Avatar
SDDL-UP
There's plenty of material on the crank to clean it up. I would not hesitate to go 0.020" or 0.030" to clean one up.
As far as parts go you could have Tim Meyer bush a set of his Molnar 400 rods for a 351C sized piston pin and it would open a world of options for pistons. The custom Keith Black pistons TMeyer sells are an excellent choice if you want to bump the compression up a bit.
Tim has a lot of BIG projects going right now, but he is also THE source for most dedicated 400 performance parts.
What is you budget and end use?
Old Nov 13, 2016 | 11:18 AM
Thunderhorn
Well what i want and what i expect are different. What I want is 400 Hp and 500 ftlbs all under 5000 RPMs with roughly 9.3-1 compression on pump gas and 15-20 mpgs with an engine that i dont have to touch for 100K. What i expect is 300 HP and 400 ftlbs on pump gas that gets more than 10mpg. I expect to spend about $2000 to get it running. Supposedly Tims around $1000 kit is good for 325 and 400+ and includes cam, springs, lifters, pistons, bearings, oil pump, gaskets, and some other goodies. if that is true and all works out it will be around $500-700 more for the machinework and the carb I need is about $400. add on another $300 for stuff i cant think of right now and another 15% for BECAUSE ITS ALWAYS MORE THAN YOU EXPECT and im way above my budget already.
End use? I guess if i ever finish the entire truck i want to take my wife and the trailer that we dont have and dogs that we dont have camping across the country with the gas money we dont have.
Old Nov 13, 2016 | 07:47 PM
SDDL-UP's Avatar
SDDL-UP
Thunderhorn,
The good news is, other than mileage, your "want" and "expect" aren't too far apart! Honestly 300HP is a given with a decent rebuild. Bump the compression up as you are planning and add a decent camshaft and 350 is pretty easily attainable. 400HP seems to be the domain of roller cams and yes, 5,000RPM - at least with iron heads.
Tim's oiling system modifications are worthwhile on any rebuild IMO. The bump in compression will allow you to choose from a wide selection of cams and Tim can certainly get you a suitable cam. ARP rod bolts are a must I think and an ARP oil pump drive shaft too, cheap insurance.
Good luck with you build - they are ALWAYS more than you think. LOL!
Old Feb 13, 2017 | 04:05 PM
Thunderhorn
Well tax season is here and its looking like i might be getting a decent return. So its almost time to buy my parts. This is the kit i am figuring >> https://www.dropbox.com/s/06d37v7d9v...ular%20Kit.xls
The only questions i have now are, which cam and timing chain should I choose? Ive looked up the cam cards but I am not positive on the correlation between those numbers and what i want. from what i can tell the extreme energy will give me the most bang for my buck without making my idle too sloppy like the thumpr, but i am really not sure. And as for timing chain i don't even know what difference any of it makes (ignoring gear drive). I plan on asking Tim if he can 'walk' my machinist through his oiling system mods but i don't fully understand that either.
Old Feb 14, 2017 | 12:33 PM
beartracks's Avatar
beartracks
As i understand it the crank surfaces are hardened. If you pass.010 you may eat into it. You may also need to radius grind the edge.
TMI
Mar 2, 2017 11:29 AM
BiltFordTuff
Apr 18, 2015 04:12 PM
daytomann
Oklahoma Chapter
Jul 17, 2014 08:36 AM
dmbjp
Aug 2, 2004 12:09 PM
dustinleavitt2000
48
Sep 9, 2003 11:52 AM
