Just Joined the Fuel Injector/New Engine Club
Good lord you took apart a lot of stuff. When I pull them from the top I pull the intake, alternator, fan, unbolt the PS pump and leave the lines attached, cowl, and hook the chain to the block at the top bellhousing bolt hole and alternator bolt hole. I've never tried leaving the intake on I'm not sure if you can raise it high enough to clear the crossmember before you hit the top of the firewall. BUT, you can pull the head in the truck and since you disconnected the master cylinder I would pull the brake booster to give you a lot more room.
Anyways, finally got the intake manifold off...wow what a PITA so many hang ups on the back of it. I'm tempted to try to just pull the passenger side head without pulling the engine. Looks like the CPU will have to move out of the way. Since I only need the second from front cylinder accessible.
Btw...I miss my old 77 f150 straight six....so much dang room...want to pull the heads? Then all you had to do is pull them...didn't have 57 wiring harness connectors to label either
yah I don't know where I got #7 from, at that point I hadn't seen the truck yet. I think that's just what the service writer said over the phone
Yah not looking forward to that. Wish I had the setup to do that. I can't even get my truck in the garage though because it faces the alley way and I don't have enough room to turn that long girl in. So I'm stuck with our gravel driveway....my hoist doesn't roll too great on there.
So at this point I'm pretty sure I can pull the head without pulling the engine. I pulled the left valve cover off and I should have clearance to get the head off once I pull the timing chain cover (I think it has to come off, need to look after this). we'll see but I'd rather not fuss with pulling the engine with the hoist rolling on gravel.
Damage to the cylinderThe cylinder is only damaged on the very bottom. It's only a 1/4 inch or less. I'm thinking I should be good since none of the rings go down that far.
Maybe I might just burn through a little more oil?
A little bit of the block was also chiseled out too
You can see if you zoom in
#29
Just Google "Ford 5.4 fuel injector issues problems" and you'll find what you're looking for.
