Replaced the brake booster and sealed up an open vacuum port. Started her and she sounded horrible. Was about die out. So the previous tune was setup for high idle mixture. Turned the idle mixture in till I hit the bottom then turned a 1/4 counter clockwise and now running great. Just fine tuned the carb after that. I made 3 full turns on the idle mixture screw till I hit the bottom so no wonder why my truck was guzzling gas before. This should help lower the CO output now correct? Since now I'm not flooding my engine with gas?
Yes that should help. As has been stated you need to make sure the secondary air injection is functioning correctly as it's main purpose is to combust unburnt hydro carbons. Someone adjusted the carb to compensate for the vacuum leak. So still a good idea to check your cats you have to do this with the engine at operating temp.
I was feeling frosty enough to take my truck back for emissions testing to see if I had improvements. Here were the readings and results...
Emissions Readings:
Code:
Pollutant | Vehicle's Emissions | Standard Emissions | Result
HC | 4.68 | 3.00 | FAIL
CO | 143.48 | 25.00 | FAIL
NOX | 0.95 | 4.50 | PASS
I think I got to replace my catalytic converter. I tested it with a temp gun I borrowed from my neighbor (who is awesome because he's got a chevelle). The temperature of the pipe in front of the cat converter was colder than the pipe exiting the cat converter. Cat converter obviously isn't doing it's job anymore. While I'm at it, I will probably replace the O2 sensor as well (located for me toward the bottom of the exhaust manifold, where the exhaust manifold meets the cat converter). I will also check my secondary air injection.
Emissions Readings:
Code:
The inlet to the cat (engine side) should be lower (colder) than the outlet (tail pipe side).
Your HC (Unburnt Hydrocarbon) is lower (almost there).
The secondary air system looks to be functioning (at least partially), but verify.
But CO (carbon monoxide) is way to high this is symptomatic of a cat this is not working properly or combustion issues (see below)
You will need to set the carb with a vacuum gauge. Your NOX is actually bit low indicating cold combustion this could be a function of timing , idle air not quite dialed in or leaking EGR valve or the system not working properly. Cold combustion can raise CO levels.
Double check your cat and post the temps with the engine at idle at operating temp. We will be bale to tell you is the cat is good or marginal.
Im in the exact same situation than you! Same carburetor, does anyone knows how to tune them? I having a hard time finding infos online...
Just got back from the inspection and my result were:
Anybody knows what I should do? I just got back my truck after an engine swap and I think I need to tune the carb before going back, I was idling at around 950/1000rpm, maybe thats the explanation?
EricTheCarGuy on YouTube wouldn't be my first choice in DIY advice for our trucks given that he is dealing with much newer Sequential Port Injection in the video.
Back to working on my truck today. Finally gave in and had my emissions checked out by a mechanic. He looked at my catalytic converter and could tell already that my cat was burnt. They cut it off and we saw that the cat was burnt inside. Getting a new one welded on as I type. Now I know what a burnt cat converter looks like . I guess running the truck with the vacuum leak and idle mixture turned up to compensate for so long it burnt my cat converter.
Be sure the AIR injection is working properly. It will generally take care of most (not all but most) of the extra hydrocarbons in the exhaust.
The cat would not melt at idle not enough heat or flow, that would happen at higher engine RPM's. Replacing the O2 sensor is the correct move you should always replace the O2 sensor when you do the cat/cats any way, just a good practice...
Well I know this truck had been running to rich and with the vacuum leak for at least 3 or 4 months. That's why I am assuming that charred my cat converter. Trying to replace O2 sensor now. How do I check to see if the AIR injection is working?
Just by curiosity, how could they know that it was your cat converter? I wonder If I have to replace mine too but Id love to be sure before I actually do it. Also how much did it cost you? just to have an idea
Thanks!
Thanks!
The guy looked at my catalytic converter and saw how black it was. He said, "Yep, you're catalytic converter is done for..." He then cut it out and saw the inside. It was completely black and charred on the inside and a small crack on the honeycomb part.
We negotiated a price and was able to get $100 for part and labor. He welded it in in less than 10 min.
You need to test the pump to make sure the pump is pump actually moving air,
that the diverter valve/s are working, that the check valve is only flowing one way, that the piping is intact and not blocked and that the control system is working. With out seeing the emissions sticker I can not really give you a step by step.
