Fluctuating RPM's
Old Nov 6, 2016 | 04:07 PM
hharris8's Avatar
hharris8
I believe I did it backwards as Gary said. I knew something felt wrong. I will check it the other way and get back with the results.
Old Nov 7, 2016 | 04:39 PM
hharris8's Avatar
hharris8
I redid the test correctly. Here are the results:
Idle: 575 RPM (± 20 fluctuation) vacuum of 0
Revved engine to 1000 RPM (± 0 fluctuation though it flickered to 1010, but I think it was the tachs fault) vacuum of -5
Revved to 2500 RPM (fluctuation ±10) vacuum of -20
When the engine is revved to 1250 (I did not check at higher speeds) the advance seems to differ by one switching back and forth.
Old Nov 7, 2016 | 05:57 PM
Gary Lewis's Avatar
Gary Lewis
If you are only seeing a fluctuation of 20 RPM on a digital tach at idle you are chasing ghosts. Can you hear any RPM change? I doubt it, and I doubt there is a problem. These aren't fuel-injected vehicles. Some authorities have said it is amazing that engines will even idle, much less do so smoothly.
Old Nov 7, 2016 | 07:09 PM
FuzzFace2's Avatar
FuzzFace2
I am with Gary if only 20 don't worry but if say 200 then worry.
Dave ----
Old Nov 7, 2016 | 08:41 PM
hharris8's Avatar
hharris8
I meant to add this to my previous post.
I added a clamp around the hose where it connects to the carb and that dropped the fluctuation from 75 or so to around 20. I think it may have just been a vacuum leak because that hose was pretty loose on there. Would that have caused the fluctuation?
Old Nov 7, 2016 | 08:50 PM
Gary Lewis's Avatar
Gary Lewis
Yes, that could cause problems.
Old Nov 7, 2016 | 10:41 PM
Rusty_S's Avatar
Rusty_S
Gary, I actually am running full vacuum on my dist. I tried moving it to ported vacuum and the truck just had a roughness in the idle. rpm didn't move on the tach it was steady but just a roughness in the truck. Switched it back to full vacuum and now with the A/C off you cant even tell the truck is running it is that smooth running.
I think some engines will like manifold and some will like ported. I know my emission sticker says it should be ported. But doesn't like ported. My '78 Mercury is set to ported and was when it was running idled great but that could have been due to the fact I have a primitive map sensor that works in conjunction with a yellow DS2 box to advance the timing more than the vacuum and mechanical advance can during high vacuum settings.
Old Nov 8, 2016 | 08:36 AM
Gary Lewis's Avatar
Gary Lewis
I've not encountered an engine that doesn't work well with ported vacuum. However, they will require the idle stop screw to be turned up as the idle will be much slower without the vacuum advance. On the other hand, I can see that an engine will "like" an extra few degrees of timing at idle, and that could cause it to feel like it is running more smoothly.
The problem I have with ported vacuum is that usually the advance is set to be in the middle of its advance range with the vacuum the engine produces at idle. That means that any fluctuation, like the A/C compressor coming on or going off or the choke coming off or dropping the transmission in gear, will change the engine's RPM. And that RPM change changes the vacuum, which changes the advance, which changes the RPM, which..... Basically you are in a feed-back or for/next loop and any change has ripple effects.
However, if you use a vacuum advance that isn't in the middle of its adjustment range at the vacuum the engine generates at idle you can get away from those problems. But, that takes investigation and tuning, and most people don't know how to do that.
thedopefishlives
Mar 17, 2017 05:31 PM
yankeerebel
Nov 14, 2010 11:50 AM
marcograms
Jul 8, 2010 06:56 AM
hotrodford_88
Jan 14, 2003 09:55 PM
tombob
1978 - 1996 Big Bronco
Dec 6, 2001 08:25 PM
