Timing Advice
Old Nov 1, 2016 | 06:48 PM
JKessler00's Avatar
JKessler00
Hmm, I feel like I'm robbing myself of power by sticking with this thing. I have a fresh stock replacement distributor but I'm not sure if it'll play well with the ignition box attached to the current distributor (6AL 6425). I guess I've got some reading to do. Just in time for cold weather too
Old Nov 1, 2016 | 07:20 PM
Filthy Beast's Avatar
Filthy Beast
If you want to keep it, put it in an old Mustache with a slightly built 289 and make a stop light tire smokin' go faster out of it...hehe.
Be aware that the DSII requires an ICM, coil and ballast resistor wire between the ignition switch and coil.....
Wish you the best in whatever you decide. Keep us informed?
Old Nov 1, 2016 | 07:53 PM
orangeford's Avatar
orangeford
Distributors without vacuum advance are made for wide open throttle applications. You can make it work it will just be finicky in part throttle operation. Vacuum advance give more advance when vacuum is high. And helps with cruising and general driving.
Old Nov 1, 2016 | 09:12 PM
PapaBearYuma's Avatar
PapaBearYuma
Originally Posted by Filthy Beast
Ok. After reading some of the specs sheeit, you have no vacuum advance...just mechanical. I believe this type of distributor wasn't made for our vehicles.
And it's the wrong color to boot!
Old Nov 2, 2016 | 07:11 AM
Filthy Beast
I was hesitant about saying that....but I'm glad you did!
Old Nov 2, 2016 | 02:48 PM
tbear853's Avatar
tbear853
And better for gas mileage.
Years ago I marked my HB all the way to 40 degrees BTDC. I also installed a quick advance spring kit. Way I set timing on my 351M is unplug vacuum and plug hose, loosen clamp, start truck, shine timing light on HB and pointer and adjust so it's 35 degrees BTDC at like 2,000 rpm or more .... at an rpm where the centrifugal advance is all "in". That's the same place it'll be at under WOT once rpm is fast enough to fully swing the weights out and vacuum is low because WOT.
Then I reconnect the ported vacuum and test drive.
I have checked vacuum advance with rpm, just elevated in neutral ..... and I know it's up in mid 40s anyway, maybe more .... but tipping the throttle drops it as vacuum drops. I get no spark knock.
Once I added that spring kit those many years ago I found I no longer could use initial timing per OEM specs.
Old Nov 2, 2016 | 06:26 PM
JKessler00's Avatar
JKessler00
I went out tonight and set my carb back to spec per the manual (it was used when I bought it) and set my initial timing at 20*. I also installed the medium springs. While tightening down the distributor, the bolt stopped tightening. The threads are stripped out...unbelievable. It looks as if there is maybe a 1/4" depth to the hole so I'm not sure how many teeth of the tap will even catch if I drill it out now
I got it just tight enough so that I could hear how the engine ran and confirm the 20* without the distributor moving but as soon as it gets hot (and this motor gets hot), I have run-on.
Anyone live near Toledo and want to make a few dollars tuning this thing? After almost 8 years, I'm tired of the lack of progress.
Old Nov 2, 2016 | 07:32 PM
Filthy Beast
Stripped threads....Oh, man! Now that takes the rag offin' the bush!
Run on, or "dieseling" is caused by hot spots of carbon (unburned fuel) in the combustion chamber or on the plugs after the engine is shut down. The momentum of the engine's internals after shut down will draw a certain amount of air/fuel back into the chamber....the "hot spots" would then ignite the fuel..... = dieseling.
What are your thoughts on going back to the DSII....or and HEI? Might get you feeling better about some progress?
Old Nov 3, 2016 | 05:37 AM
JKessler00's Avatar
JKessler00
I think that's going to be the plan at this point. I have nearly all of the original components. What's stinks is the change in wiring. I have the entire American Autowire kit and everything is nice, neat, and clean.
I pulled a plug and the tip was a little wet so there's the confirmation; now to figure out why.
Old Nov 3, 2016 | 06:56 AM
Filthy Beast
Yessuh, the wiring changes bite...I noticed the new wiring in the picture you posted.
Not to push the HEI, as I have no dog in that fight, wouldn't it be easier to spend the dollars on an HEI rather than expend all your time/energy on back to stock wiring?
You already have the wiring set up for it.....I suppose it's a question of time vs money.....just throwin' it out there.....
Wet/gas fouled plugs: Timing, too much fuel (carb internals/settings), not enough or not a healthy spark, too cold a plug heat range, old plugs or gap too big, blown power valve, etc. I'm sure you know all that.
Strike the power valve thing.....you have a Carter carb....too much fuel pressure could be a consideration for gas fouled plugs.
Old Nov 5, 2016 | 09:40 AM
JKessler00's Avatar
JKessler00
I think you've got me sold on the HEI setup. It seems the most logical and best setup.
I was out this morning to drill/tap a new hole for the distributor retainer and that is back to new. Any tips/secrets to getting the oil pump shaft out?
One other thing I wanted to mention is that I'm running Denso T16PR-U11 plugs gapped at about .040". Sound ok?
Old Nov 5, 2016 | 09:51 AM
PapaBearYuma
Unless it's been previously removed, the oil pump drive shaft has a retaining clip on it, with a larger OD than the hole the shaft might come out of. Dropping the retainer in the pan wouldn't be good. Probably best to pull the pan and pump, and pull the shaft out that way
Old Nov 5, 2016 | 12:13 PM
  #28
Jonnyuma's Avatar
Jonnyuma
As I read every post in this thread my thought was "HEI. HEI. HEI". If the wiring wasn't already set up for it (the main hangup on most new HEI installs), I'd say go back to stock.
I've bought a couple of the sub-$100 units off of eBay and was pretty impressed. Solid build quality with a few corner-cutting, but easily upgradable, cheap Chinese parts...your local NAPA (or Chevy buddy) will have the good stuff and you'll still be into for half the price of a Davis. I also recommend driving out the roll pin and perma-lubing the shaft w some good synthetic grease.
BTW, it does help if you've got a GM-friendly bud to help you along w your first one. When I bought my first one for an old small block Charger, my GM buddy not only helped me with knowledge, all the "upgrade" parts were already in his spare parts box. Yeah...that worked out well.
Old Nov 5, 2016 | 06:20 PM
  #29
Filthy Beast
PBYuma is correct about the clip on the oil pump shaft....it's there to prevent the shaft from partially coming out with the distributor only to fall back into La-La land.
Why do you want to replace it, if I may ask?
HEI sounds like the hot setup for you...agree with Jonnyuma on that.
Plugs like to be gapped at 0.044." You can go larger on the gap with an HEI but I wouldn't....for the time being.
Old Nov 5, 2016 | 06:34 PM
  #30
JKessler00's Avatar
JKessler00
I don't want to replace the shaft. I can't get the distributor to set back down on top of it so I thought it might be easier to install as one unit.
