Engine swap: 2005 6.8 V10
35 toooo 40 Hours R U Nutz .....or Just a BoltUDolt.
35 tooo 40 HR to swap a V10 no way dude even on a bad back day I can swap them out in about 6 Hrs not a problem but I have been doing this for 45 plus years so go figure you wont make any frieneds quoten them those kinds of labor rates 160 X 35 Hr =5600.00 bucks. ouch !!!!!!
Good Luck with that R&R even if rusty should not exceed the books 11hr lists for the 514 Cube.
have a great rest of your year
the Zen MEchAniC
the Zen MEchAniC
run would need to include the transmission as well, your standalone controller will not also run the 4R100, so you would probably have to go ZF6, then you also would not be able to use the electronic 4x4, so you would need to get a manual transfer case as well.
Have fun with all that.
The following users liked this post:
Im all for modernization to keep things going, but i don't think you realize just how much stuff won't work right with the 7.3 and the new ECM in there, all the gauges, the fuel pump sender, the tank level sensor, none of that is a direct crossover, going to have to sort it all out and likely rewire a lot of it, and no, the sender from a F250 or F250 will not just swap over, Excursions had a unique setup due to the massive fuel tank.
The emissions problems @WE3ZS brought up are a large stumbling block for most people as well.
Your 6 speed might adapt over but i doubt a transfer case will, and if your swapping the trans, NOW you also need to get a custom driveshaft made to adapt the trans to the differential, 2 shafts if you plan to even TRY to have 4x4 working eventually.
Then you need to have a transmission mount made to fit the Excursion, and hold the new transmission properly.
Have fun getting all of that sorted out, and if you even got it all working, you probably spent more than a new truck would have cost if you did the labor yourself, if your paying someone else to do the work, you spent even more.
