Sponsored by: Real Truck
Replacement Peragon Bed Cover Panels
Old Oct 29, 2016 | 08:42 PM
cdnite's Avatar
cdnite
6th Gear
My short bed 2002 F250 need the cover to be about 2" shorter to fit properly.
My panels are 13.25" wide is it possible to order the rear two panels that are 12.25" or shorter and just replace them? I assume most of their cover panels are the same length, but the width varies to match the bed length with an even number of panels.
Any help with this would be great, I love the cover and don't want to return it, but if it won't fit... i can't use it.
--Christian
Old Oct 29, 2016 | 09:44 PM
Peragon's Avatar
Peragon
PLATINUM SPONSOR
--Christian
Hi Christian -
Thanks for posting! We can definitely help sort this out for you. The short bed Super Duty is one of our more popular models, so I'm confident the sizing is correct and it is just a question of positioning the frame. The rails at the tailgate should be set so the bottom of the notched out area is 3/16" from your tailgate. The top part of the rail will hang slightly over your tailgate. I've asked our Support team to reach out to you this evening, they will be able to assist better than I can since they troubleshoot regularly. They may request photos or check a few dimensions. I'm glad to hear you're otherwise happy with your new Peragon cover!
- Heath
__________________
Heath Copp
President, Peragon Enterprises, Inc.
www.peragon.com
Old Oct 31, 2016 | 02:39 PM
cdnite's Avatar
cdnite
6th Gear
WOW!
Thank you so much for the incredibly fast reply.
I'm discussing the issue with support now.
Thank you for your help,
--Christian
stangfan78
2009 - 2014 F150
Mar 16, 2024 01:05 PM
JimRay
Jun 9, 2016 03:57 PM
Casey_78
2009 - 2014 F150
Aug 21, 2015 06:32 PM
cecilt
Feb 25, 2011 11:25 PM
Garycas
2004 - 2008 F150
Nov 17, 2005 01:16 PM
