Fuel pump/filter
Old Oct 29, 2016 | 07:55 PM
Furr308's Avatar
Furr308
Fuel pump/filter
Hey, I'm helping a friend with a 91 f150xlt with the 351 auto 4x4. It sat for a while and has some bad gas in it. I can't find a fuel pump or filter mounted in the frame rail. My 89 bronco had that set up. I don't know if I'm just missing it? Or are the pumps in the tanks the only ones. And if so, wheres the filter? Thanks in advance
Old Oct 29, 2016 | 08:00 PM
court1100f's Avatar
court1100f
yup in 90 they went to dual pumps and retired the triple setup, As for the filter location it is still under the cab practically on the firewall
Old Oct 29, 2016 | 08:02 PM
Furr308's Avatar
Furr308
Ok, so is the filter still supposed to be in the frame somewhere?
Old Oct 29, 2016 | 08:08 PM
court1100f's Avatar
court1100f
yup it's in a bracket on the driver's side under the cab right at or slightly past the Firewall need a flat head to loosen it after popping those annoying retainer clips out and the in slides forward and out
Old Oct 29, 2016 | 08:09 PM
court1100f's Avatar
court1100f
On a Different note if it has bad gas in it it'd be best to drop the tanks remove the pumps clean the sediment out of the tank and replace the fuel pump strainer trust me on this I'm dealing with this problem now myself on an 89 extended cab that sat for 2 years
whiteaddiction
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sep 10, 2012 02:25 PM
old76er
Nov 11, 2009 09:26 PM
96f150
Oct 22, 2008 06:47 PM
reflex26
Bronco II
Jul 26, 2007 02:17 PM
Cape Breton Explorer
Oct 17, 2005 10:09 AM
