Which axle do I have?
Old Oct 28, 2016 | 11:24 AM
wirelessengineer's Avatar
wirelessengineer
I have a leaking rear seal, and could use some help identifying my axle. There is no tag.
From what I have found online, it's either a full or a semi-floating axle. 1996 E350 Club Wagon. Basic 12 passenger model, no power anything.
Here are some pictures of the axle. I found numbers cast into the housing, which I have circled.
Old Oct 28, 2016 | 11:47 AM
Sam I Am's Avatar
Sam I Am
Looks like a Dana 60.
There should be 2 sets of numbers stamped into the axle tube and at these other locations, you may need to use something like Brakleen and a nylon brush to clean it enough to read them.
Old Oct 28, 2016 | 11:49 AM
djbonsu's Avatar
djbonsu
More than likely it is a dana 60 Full-Float. Most of the 1ton passenger vans came with that up until 2001 then they started puttin semi-floats in the 1 tons randomly for some reason. You can also look up the axle code printed on the sticker located in the drivers side door jam --> Identify Your Ford Truck Axle From The Door Sticker
Old Oct 28, 2016 | 11:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1996 E350 could have either a Dana 60 or Dana 70, both look pretty much the same.
Post the AXLE code printed on the Certification Label.
The Ford AXLE ID tag is located under two of the bolts that retain the inspection cover to the housing. By reading it, will ID the axle and the ratio.
Old Oct 28, 2016 | 01:25 PM
wirelessengineer
Hmmm. Maybe I have an odd beast. No tags under the bolts, no part numbers on the axle tubes. It's smooooth.
My axle code is 33.
I'm not finding a code 33 as such on my web ssearches, but I did find this thread on another forum that suggests I have "3 a 1-ton open", but then says, "There are MANY exceptions."
Well, that's helpful!
For the second digit, it's even more ambiguous. "3 = 3.54 (late), 3.73 (early), 4.10, 4.11 ".
I don't suppose that matters much, though, as far as the seals are concerned.
When I search for axle seals on the NAPA site, it offers me two choices:
Part # :NOS 17100 which is for a semi-floating rear axle
Part # :NOS 28754 which is for a full-floating rear axle
I don't know what semi-floating vs. full-floating means. Is there a way to tell which I have based on the info I've posted?
Old Oct 28, 2016 | 02:00 PM
NumberDummy
1988/97 E250/350: 33 = Dana 60.3 (semi-float) or Dana 61.1 (full float) Rear Axle / 3.54-1 / 9.75" Ring Gear (both) / No Limited Slip / 6,340 lbs. Rear Axle Capacity.
The pinion seal is the same for both: E7UZ-4676-A (replaced F8UZ-4676-AA) .. Marked with industry number: 42449
So which seal is leaking, the pinion seal or an axle seal? If the axle seal, does your E350 have single or dual rear wheels?
Old Oct 28, 2016 | 02:53 PM
wirelessengineer
Sorry, I thought I mentioned that, but I see that I did not.
Axle seals, single wheel. I have one leaking onto my brake shoes. I might as well do them both while I'm buying seals. It's only got 216k on it, and they've never been touched.
Diff cover is leaking too, so I'll get that done at the same time.
Old Oct 28, 2016 | 03:28 PM
NumberDummy
F7UZ-1175-A .. Rear Axle Grease Seal (Chicago Rawhide part number: 47507) / Available from Ford & auto parts stores.
Old Oct 28, 2016 | 06:32 PM
wirelessengineer
Thank you very much, Bill. Which axle do I have (for future reference)?
NAPA says that part number is this.
Does that look right?
Old Oct 28, 2016 | 10:10 PM
fordman75's Avatar
fordman75
The full floating rear diff has the large hub that sticks out past the wheel. Like on this diff in the picture.
The semi floating diff won't have the large hub that sticks out past the center of the wheel.
Old Oct 29, 2016 | 07:47 AM
wirelessengineer
Gotcha. Mine's a full floater, then. Off to NAPA for some seals! And probably brake shoes....
What diff fluid does that one take?
Old Oct 29, 2016 | 11:50 AM
VOODOO7.3's Avatar
VOODOO7.3
I'd go with Mobil 1, 75W90, Synthetic, and check your axle vent hose while you're at it. It's just a 16" rubber hose venting from driver's side axle shaft. If that's clogged, your fluid can't expand properly. If it's broken off or cracked, water can get in. You'll need some high heat Permatex too, and housing cover bolt torque is 35 ft.lbs. Let the silicone dry for at least one hour before filling housing. I usually let it cure 4 hours or overnight though. Cheers!
Old Dec 3, 2016 | 11:53 AM
wirelessengineer
Had to back-burner this while I dealt with a water pump and other such woes, so now back to this. Because of the time burned with a water pump replacement that went wrong in every possible way (broken bolts, etc.) I'm considering letting the shop do this. I'm just short on time.
But they want $725 for the job! That's both seals, but still, seems pretty steep.
How big a job is this? Do I need any special tools other than a standard hook-type seal puller, and a press to put it back in? (Got both.)
If I'm going to spend that money, maybe I should get a junkyard axle from a later van that has disc brakes. Would that also get me into a limited slip diff?
What years will work? Up to 2002?
Old Dec 3, 2016 | 05:22 PM
fordman75's Avatar
fordman75
If you have ever changed front wheel bearings & seals on any 2wd truck, van or older rwd car it's basically similar just much larger and a few additional steps. The seals are in the hubs not the diff housing. The only special tool you will need is the socket for the spindle/hub nut. You have to remove the small bolts are the center of the rear hubs, then pull the axles out. Once the axles are out you can get to the spindle/hub nuts.
Here's an article on another site that shows what's involved. But that is a Sterling rear diff not the Dana 60.
TheDieselStop.Com - www.thedieselstop.com
Here's a youtube video that shows the D60. It's not a step by step video but gives you an idea of what's involved. He had to deal with repair sleeves( wear rings ) . You shouldn't need to deal with that unless your spindles are messed up.
If you are concerned about being able to replace the rear axle seals. Do not even consider trying to do the disc brake rear diff swap! There is a lot more involved then just swapping the rear diffs. you'll be a lot better off just replacing your seals.
Old Dec 3, 2016 | 07:46 PM
wirelessengineer
Thanks for that video. I had been looking for one and couldn't find any. That job does not look like a $725 job to me! Other than buying one special tool, it looks pretty straightforward.
Oh, I wasn't going to swap the brakes and the diff. I was thinking about the entire axle assembly as one piece. Looks pretty easy, really. 4 bolts on each side, the shocks, and the brake lines. Is there something I'm missing about that?
