Full gauge cluster
Old Oct 28, 2016 | 07:22 AM
idealtrucks's Avatar
idealtrucks
Full gauge cluster
Good morning,
Am I correct in thinking that the wiring harness is different on the trucks with full gauges vs warning lights? I guess it's not as easy as changing out the cluster and sending units, right?
Old Oct 28, 2016 | 07:31 AM
ultraranger's Avatar
ultraranger
If you're referencing the Ford F500-up Bumpside/Dentside big trucks, the instrument cluster is a direct connection into the main wiring harness on '67-'69 model F100-F350 trucks.
On a '70-'72 F100-F350 trucks, the connector and a short length from the main wiring harness would have to be cut from a '67-'69 F100-F350 or F500-up donor truck to connect the big truck cluster to the main harness of a '70-'72 model truck, since '70-'72 has a printed circuit board cluster and not a hard wire cluster. --although, I did have a printed circuit board cluster that came out of a '78 model F600. It resides in Connecticut now.
Old Oct 28, 2016 | 07:34 AM
idealtrucks
Actually I was referring to a cluster out of an F100. With printed circuit.
Some have the warning lights lights, and some have the guages (oil and amp I think).
Old Oct 28, 2016 | 08:35 AM
ultraranger
In that case, yes. A full instrument cluster will not work on a wiring harness that's designed for a cluster that has idiot lights.
You'll have to have the cluster harness designed for full instrumentation to make it work.
Old Oct 28, 2016 | 08:53 AM
orich's Avatar
orich
This is why some guys just use the aux add on aftermarket under dash mounted gauges for the oil, water temp & amps sets.
Orich
Old Oct 28, 2016 | 09:01 AM
idealtrucks
Thank you all. I do have the aftermarket underdash ones. Would like to have them originally in the dash, but won't be changing out wiring harness
Old Oct 28, 2016 | 11:44 AM
orich's Avatar
orich
The gas gauge was about the only thing that worked good until the float went bad. Then the speedometer started bouncing. This when many of us bought custom replacements. Or we build or own. Which, I did two time as this is my last one which not to hard.
I'm using a electronic speedometer so it can corrected for any speed & odomer with any size tires
Orich
F-250 WARHORSE
Feb 6, 2018 10:11 PM
Big Big Blue
Jan 6, 2015 07:18 PM
Vin Man
Electrical Systems/Wiring
Nov 29, 2012 10:05 PM
Ole Green 1978
Jan 23, 2012 09:37 PM
Ford_Six
Feb 5, 2011 09:33 AM
