fuel problem
I have two problems.
SOMETIMES after starting(wich requires a lot of peddle pumping) the truck belches black smoke (too rich)and will not idle. Turning the idle up will keep it running. Then, (sometimes) after a 20-30 mile drive it purrs like a kitten and now the idle is too high, I can turn the idle back down and things are fine untill the next time it decides to act up. It has got to the point of instead of saying I'll get the truck, its, I'll go see what mood the truck is in. This has been going on for over a year now.
2nd problem just started on my 50th birthday(AUG 20) while trying to get to the lake with the boat. The rear fuel tank will not work. I found a relay that clicks when you go from center of the selecter switch to front tank but not from center too rear tank. The guy at NAMPA told me he would sell me a new relay ($25) but if that was not it it was still my relay and to go home and try swapping relays(at least 3 of the same type on truck). well that sounded like a good idea but i could not find the other relays. durring my search i discoverd that i have electric fuel pumps in the tanks. (this is actually my girlfriends truck, i'm just starting to dig into it) I saw something on the net durring my search, wich led me to this site, concerning the in tank pumps and check valves which, if bad, allow fuel to flow from tank to tank or some such thing.
I am now thinking (watch out) that maybe my first problem and the new one could be related.
Then again i might need a new carb and fuel pump.
I have put of getting a new carb because of the cost (~ $400.00) and i just cant believe a come and go problem could be in the carb.
SOMEBODY HELP ME PLEASE Thanks
