1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Normal readings at Data Link Connection?
Old 10-26-2016, 10:34 PM
truckerguy's Avatar
truckerguy
truckerguy is offline
Anyone know what the normal readings would be at each of the pins when probed with a multimeter? KOEO
2003 F-350 6.0
I've got...
pin#2 0.2v
pin#3 10.8v
pin#7 1.5v
pin#10 4.8v
pin#14 2.4v
pin#16 12.6v
Old 10-27-2016, 05:43 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
The better question is WHY? are you poking around the DLC with a meter.
Old 10-27-2016, 06:24 AM
RightWingNutJob's Avatar
RightWingNutJob
RightWingNutJob is offline
It's a data port, that follows the automotive "CAN Bus" data standard.
You will only read a stable voltage from the power & ground pins that would normally power an OBDII scanner. For all of the other data lines, the multimeter is going to read an in-between voltage that is an average of all the ones and zeroes that are toggling by it.
Here's the pin out description of the OBDII connector
Old 11-01-2016, 06:01 PM
truckerguy's Avatar
truckerguy
Can I assume that if there is any voltage at the data lines, there is nothing wrong with the data plug?
Old 11-02-2016, 06:34 AM
RightWingNutJob
If you can measure voltages on the data lines it means that you don't have any broken wires and the pins are hooked up. It's better than no-voltage, but it doesn't prove that the port is working correctly. (Wires could be shorted together or to 12 volts.) The OBD-II system is repeatedly "polling" the connector to see if something is plugged into it; but until it detects a scanner, there's relatively little activity on the data lines.
The easiest check is to plug in some sort of OBD-II Scan tool - standalone, phone or tablet-based, or laptop based scanner. Do you have an Autozone; Pep Boys, etc., near you? They will scan your vehicle for free (or minimal cost). If there's something wrong with the data port, the scanner will flag it in about 20-30 seconds. (Communication Error).
Old 11-02-2016, 06:38 AM
projectSHO89
Except in CA which is where the OP is at.
Old 11-03-2016, 02:00 PM
The Kaz's Avatar
The Kaz
The Kaz is offline
2003 F-350 6.0
I've got...
pin#2 0.2v
pin#3 10.8v
pin#7 1.5v
pin#10 4.8v
pin#14 2.4v
pin#16 12.6v
my guess is you tried to plug in a scanner that requires the OBII plug to be powered up but because the fuse is blown the tech said your OBDII port is dead LOL If this is the case then you only need to worry about #4 ground and #16 Battery ..... power is usually the cig lighter or power port fuse
Old 11-03-2016, 03:22 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
Yup. IIRC it's F2.12 under the steering wheel.
truckerguy
Electrical Systems/Wiring
01-07-2018 07:12 PM
frustrated mechanic
2004 - 2008 F150
06-05-2015 09:45 PM
erikkloss
6.4L Power Stroke Diesel
08-10-2014 08:39 PM
77300i6
1983 - 2012 Ranger & B-Series
10-15-2007 08:55 AM
subford
04-18-2006 09:10 PM
Quick Reply: Normal readings at Data Link Connection?
