Snap, crackle, pop when turning. I counted 8.
Old Oct 26, 2016 | 09:29 PM
Resendiz's Avatar
Resendiz
Nothong is in the way of the steering column, bar. The music flaps are also not in the way
Old Oct 27, 2016 | 08:56 AM
Jarkill's Avatar
Jarkill
Can you stand outside and watch it while someone else turns it? Is this a 4x4 or 2wd?
If 4x4 it could be a U-joint if you can't see a tire rubbing anywhere
Old Oct 27, 2016 | 09:08 AM
264WSM's Avatar
264WSM
Can't speak for Ford, but on a Freightliner it is the bushings on the front part of the leaf springs. My Ford doesn't have zerk fittings, so there is no way to grease them. I don't even know if you can get the bushings separately or if you have to get new springs.
Old Oct 27, 2016 | 09:39 AM
Jarkill's Avatar
Jarkill
You can get the bushings separate from the springs. If it is bushing noise, I would look at the front hanger shackles. the bushing up in the frame can get noisy as hell when they fail
LCAM-01XA
18
Mar 17, 2010 10:40 PM
myblkex
Jul 1, 2009 06:32 PM
Scolesy8
Dec 27, 2008 08:35 PM
BOBSDIESEL
Jul 19, 2006 04:27 AM
kenneBF250V10
Oct 1, 2004 03:20 PM
