03 navi rear suspension wont kneel
Hi all,
I have searched for the problem I have to no avail.
What's happening is, the front air bags while driving down the road, inflate and deflate while driving. I should mention, the truck does sit as it should with no leaks in the airbags. (The rear may be a little higher than normal imo)
The front does this no matter the speed. Its like it is kneeling while driving, then reinflating. It cycles constantly doing this.
When I park, the front only kneels while the rear does not kneel. As I mentioned earlier, it does seem to sit higher then normal while parked.
I know, its totally opposite then the guys that have the problem of it not airing up! Lola
My question is, where should I start to look for what's causing this?
Thanks
Fixit5561
Thanks
Fixit5561
Ok, ive got the sensor off the truck. It moves freely, and actually seems to move too freely. How do i use an ohm meter to test the sensor?
I put my test leads on the 2 outside pins and moved the arm up and down, got nothing. Then put the leads on the middle and right pins and got just a 165.3 reading no matter the position of the arm on the sensor. Then put leads on left and center pins and get nothing.
Am i testing this correctly?
I can see it doing that because with the rear pumped up too high the geometry of the vehicle is being thrown off. I'd fix the rear and see if the front takes care of itself.
talltorontoguy
1997-2006 Expedition & Navigator
06-24-2015 10:06 PM
