headliner adhesive
Old Oct 26, 2016 | 06:14 PM
lafermedavid's Avatar
lafermedavid
headliner adhesive
trying to find best adhesive to build your headliner,I'm using Naugahyde over pvc template,3m did not work that well for me.any suggestions
Old Oct 26, 2016 | 06:24 PM
Justin73supercamper's Avatar
Justin73supercamper
I used this stuff bought it a Joanne fabric. For under 20 bucks. I made mine around June holding up great
Old Oct 26, 2016 | 06:25 PM
Justin73supercamper
Old Oct 26, 2016 | 06:29 PM
Justin73supercamper
Sorry for the double post
Old Oct 26, 2016 | 07:52 PM
lafermedavid
Thanks Justin,,,Back to JoAnns I go,a real regular
Old Oct 26, 2016 | 09:13 PM
tinman52's Avatar
tinman52
Welder User
Naugahyde, or any vinyl is a pretty heavy weight material that isn't usually used for headliners. Over time gravity wins.....
I have had good luck with the Permatex headliner adhesive(orange can) for light weight fabrics.
Old Oct 27, 2016 | 05:49 AM
buckin69bronco's Avatar
buckin69bronco
Dap Weldwood Contact Adhesive - Landau Top and Trim HHR Solvent Type Spray grade.
It has worked great for my interior and headliner, it's also what the two professional interior upolstry shops I have dealt with used. It can be sprayed with a cheep harbor freight gun or rolled or brushed.
Old Oct 27, 2016 | 10:49 AM
5851a's Avatar
5851a
I used the 3M Heavy Duty spray over 20 years ago and it's held on the cardboard and heavy fabric. It's a outside truck. Maybe it's the plastic letting it go.
Old Oct 27, 2016 | 11:05 AM
kwe45919's Avatar
kwe45919
For heavy fabrics I've used epoxy resin thinly brushed on with great results. Never a sag nor under extreme heat has the fabric, leather, rubber, whatever etc separated from the resin. Great for recovering dash boards where the sun hits it all the time. JoAnns should have some in their crafting sections.....wait, JoAnns is a craft store.
DOH!!
Old Oct 27, 2016 | 12:43 PM
blackjack33's Avatar
blackjack33
Originally Posted by buckin69bronco
Dap Weldwood
+1
If you are going to use a heavy material, Weldwood is the answer.
It's what the pro shops use.
Old Oct 27, 2016 | 02:38 PM
lasermike's Avatar
lasermike
The problem with PVC is that it has a low surface energy and nearly nothing bonds to it. The usual way to bond PVC involves fusion, either with heat or a solvent based glue.
You may have some luck with a specialty adhesive such as 3M 1099.
I don't know anything other than what 3M says about this adhesive or even if it's available to the general public but it's the kind of adhesive you need to be looking for.
You may get a better bond by lightly sanding the PVC to give it some tooth but I've never has success with gluing it without a solvent based glue and solvents will destroy the Naugahyde. You might also test Fusion brand spray paint as an interface between the PVC and a water based adhesive such as Weldwood water based contact cement. I've no idea if it will actually work but it's worth a try.
BiGGreen350
'80-'86 HOWTO's
51
Feb 14, 2024 12:43 AM
Mike321
Jun 8, 2017 11:02 PM
Romel77
May 3, 2015 11:32 PM
Caruso72
Aug 24, 2012 02:04 AM
Ford4Life7.3
Oct 11, 2011 01:42 AM
