Electrical problems
Old Oct 26, 2016 | 09:42 AM
ola1234's Avatar
ola1234
Electrical problems
Drove to work. Everything ok. When starting to go home again it fired right up. Died after two seconds. Nothing unusal so far. Tries to start again. Just some "ratteling" from what I think was the starter solenoid. Trying once more- stone dead! Not even a little clickfrom the soilenoid. Hmmm, checked voltage at battery, 12,8V. Used a wire to bypass the starter soilenoid. Starter turns just fine, but no start. Then I find out that all my lights are gone too except the dome light, which also turns off when I pull the headlight switch. Then I put on the hazard light- the only thing blinking is the dome light?!? Then I replaced the starter soilenoid. Starts right up and lights are ok :-) BUT the next time I tried to start, everything was back to the same. No click at the soilenoid. Lights gone. Checked voltage from battery to soilenoid. Drops to 2,7V when engaging the key. Checked battery again.12,8 V when key is off. Any ideas?
Old Oct 26, 2016 | 10:03 AM
kwe45919's Avatar
kwe45919
Seriously.......
Sounds like a ground wire short somewhere in the system. I know its an answer given a lot but check the grounds
Old Oct 26, 2016 | 11:20 AM
ola1234's Avatar
ola1234
Think I was rushing a little to fast. Been in the garage and looked over it again. The cable from battery to terminal at starter soilenoid was a little loose. Tightened it and tried again. Looks fine for now. So now I am back again thinking it was the starter soilenoid who caused the problems. Thanks!
williambaker
Aerostar
13
Sep 30, 2013 02:04 PM
margobin
Escape & Escape Hybrid
Oct 15, 2012 05:04 PM
Edsf150s
Aug 28, 2007 09:01 PM
pedrorairez
Dec 21, 2006 09:26 PM
brs127s
May 13, 2002 02:45 PM
