Over filled E4OD Trans
Old Oct 24, 2016 | 09:14 AM
1996_5.8's Avatar
1996_5.8
So I've bought a 96 f150 and I noticed that the trans has been over filled by the previous owner, and yes I checked after i drove it around. It looks like it has been recently gone through and got a new shift linkage. I was wondering, is there an easy way to drain or suck some fluid out with out taking the pan off.
Thanks,
Keegan
Old Oct 24, 2016 | 10:22 AM
Scndsin's Avatar
Scndsin
There is a rubber splice hose & 2 clamps on the return line coming from the trans cooler near the bottom of the radiator shroud. Undo the end closest to the trans & tip into a clean jar/container. You can run it for a few seconds to get more flow.
Make sure you check level hot & ideling in park.
Old Oct 24, 2016 | 09:19 PM
Lead Head's Avatar
Lead Head
I believe the '96 E4OD should have a torque converter drain plug as well. At least the '96 F-250 I worked on did.
Old Oct 24, 2016 | 09:40 PM
Encho's Avatar
Encho
The Southernmost Mod
To get to the torque converter drain plug you'll need to turn the engine by tapping the start. This is a horrible task to do alone, get someone to help and get under the truck while the helper taps the start at your command until the plug is accessible.
Old Oct 25, 2016 | 09:19 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I put a breaker bar on the bolt in the crankshaft to turn the engine over to get to the drain plug. I can do that while watching the torque converter.
Old Oct 25, 2016 | 09:55 AM
Lead Head's Avatar
Lead Head
Just remember to take the bar off before restarting the engine.
Old Oct 25, 2016 | 10:19 AM
Mark Kovalsky
Good point! That would get ugly.
Old Oct 25, 2016 | 11:18 AM
Scndsin's Avatar
Scndsin
Must say, I'm impressed.
Screwdriver/nut driver & one (1) hose clamp
vs
Breaker bar+extension+socket+turning engine+pull rubber plug+ locate pipe plug+remove same with another socket+ fluid down arm & covering hand while trying to get container under hole & trying to get plug back through 2 inch hole as torque converter drains all over socket or fingers while trying not to cross-thread plug...
But hey, he only asked for easiest.
Old Oct 25, 2016 | 01:09 PM
timbersteel's Avatar
timbersteel
Lol!!
I like that breakdown,
Old Oct 25, 2016 | 01:40 PM
White 97 xlt's Avatar
White 97 xlt
vs
Makes good sense to me, I like easy!!
Old Oct 25, 2016 | 03:14 PM
87 XLT's Avatar
87 XLT
If I had this problem I would siphon the fluid out of the dip stick tube. What am I missing here????
Old Oct 25, 2016 | 05:13 PM
Scndsin's Avatar
Scndsin
Not a thing. Do whatever works for you.
Old Oct 25, 2016 | 05:52 PM
Encho's Avatar
Encho
I installed a transmission pan drain plug, so screw all of you
Old Oct 25, 2016 | 06:02 PM
Scndsin's Avatar
Scndsin
Yeah, you & the horse you rode in on...
Notice that OP/NG ain't been back.
Think we scared him off?
Old Oct 25, 2016 | 08:06 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
for the win!
