Vibration while at stop lights
Old Oct 23, 2016 | 10:05 AM
bobsplus's Avatar
bobsplus
Noticed while at sop lights and truck is in gear and foot pressed firmly on brake, I'm getting a deep low sounding vibration approximately every 15 Seconds.... does it consistently. ....????? Does not do it while in park?????
Old Oct 23, 2016 | 10:16 AM
99SuperDuty2017's Avatar
99SuperDuty2017
Is the truck Engine warmed up. what is the ambient temp?
Old Oct 23, 2016 | 11:20 AM
17 Oaks's Avatar
17 Oaks
I get same at normal operating temps it seems to come and go at short intervals.
Old Oct 23, 2016 | 01:13 PM
felix4's Avatar
felix4
Something turning on and off? Like the A/C compressor?
Old Oct 23, 2016 | 01:22 PM
17 Oaks's Avatar
17 Oaks
Its a vibration and it sounds like the engine maybe...
Old Oct 23, 2016 | 05:33 PM
Rasty1's Avatar
Rasty1
Might be time to visit the service department.
Old Oct 24, 2016 | 07:42 AM
Force74's Avatar
Force74
I get a vibration also, but its not the engine. When the drawer is open on the center console (the one where the USB ports are), I'll get a vibration. If I push on the door or close it, it stops. By the sounds of it, I don't believe its the same as what you guys are experiencing, but figured it was worth mentioning.
Old Oct 25, 2016 | 06:32 PM
bobsplus's Avatar
bobsplus
occurs at any temp, currently driving around in 50-80 degree temps
It almost sounds like a car next to you with a bass sub woofer, as soon as I stop takes about 15 seconds last 3-4 seconds and does it every 15 seconds till I start driving again....
Old Oct 25, 2016 | 08:57 PM
wb6anp's Avatar
wb6anp
Vacuum pump? refilling the vacuum reservoir? That is if you have a 6.7.
Old Oct 27, 2016 | 06:17 AM
bobsplus's Avatar
bobsplus
I figured it out.....turned the AC off and it goes away, I guess when I get a chance i'll see the dealer and see what they will do as it is obnoxious.....
banoness
Apr 22, 2019 04:28 PM
Mattcavett
Modular V8 (4.6L, 5.4L)
May 19, 2015 09:11 AM
ROBBINthaHOOD
Apr 8, 2013 08:55 AM
hoamskilet
Nov 23, 2005 05:17 AM
