Since seeing the pics of the magic stiker I went out to th truck and found a piece of shrink wrapped cardboard, cut off the shrink wrap and bingo there they were...thanks all.
I can definitely verify that the portion of the TRG (trailer reverse guidance) that utilizes the stickers will not function with anything but a conventional trailer (no gooseneck or fifth wheel)
Was also sad that the trailer blind spot monitoring didnt work past 30ft and trailer TPMS didnt work if you had steel belted radials on your trailer...So if you pull anything big and heavy you are SOL on technology lol.
It is strange that they dont work on steel belted tires as the tires on the truck are steel belted and they work fine on them.
