Sponsored by: Real Truck
Alternator ?
Old Oct 28, 2016 | 04:51 PM
seville009's Avatar
seville009
Originally Posted by coolbrze
Fudge...
So I replaced one of the batteries & the alternator and the truck worked well all week until this afternoon. The guys were on their way back to the shop & the battery light started flashing. Is the 110 Amp alternator not enough (that's what was in the truck to begin with) or is the battery I didn't replace shot or both? What alternator do you recommend for an '06 F450 landscape dump w/ 6.0L diesel single alternator set-up? I'll order on-line as soon as I hear from y'all I guess...
i'd start by replacing the old battery. As many have advised above, the batteries should be replaced in pairs
Old Oct 28, 2016 | 05:03 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Get a new battery to match it's friend. Replace in pairs as has been said many times above.
It's not. I have two dead 110A and a dead 140A to back that up.
Call this guy and tell him your troubles. He'll sell you the correct part, and also make sure you haven't nuked the FICM during all this.
FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
I bought this alternator:
270 Amp XP Series Alternator for 6.0L
This is a good upgrade over stock if you don't want to go big:
185 Amp Series Alternator for 6.0L
This is the Leece Neville unit everyone loves lately, but make sure you order the pulley with it because it's a minor PITA to install (you need a pass through socket):
Leece Neville 230 amp alternator
If you do the underdrive pulley there's a slight chance you need a new belt tensioner depending on how slack yours is with the smaller pulley.
Honestly, THIS IS THE ALTERNATOR that you actually need.
Advance Auto sells a 140A unit, you can use the code TRT30 to save 30% on it if you buy online and ship it to your local store. I don't think 140A is enough though, I have a dead one on the shelf to support this opinion. Plus make sure you check all the cables, and add the ground cables I linked to in post #12. I did the complete cable set from FICMrepair, but there is an argument to if it's necessary or not even with a larger alternator.... the extra ground cables are pretty well unarguable based on the hard data Jack provided.
www.ficmrepair.com/index.cfm/page/ptype=product/product_id=59/category_id=23/mode=prod/prd59.htm
Old Oct 28, 2016 | 09:24 PM
FordBlueHeart's Avatar
FordBlueHeart
Why do I feel like I read this already....lol
Oh yeah, now I remember...
Alternator ? - Ford Powerstroke Diesel Forum
Another vote for the Leece-Neville 230Amp alternator.
Old Oct 29, 2016 | 08:05 AM
skanj0's Avatar
skanj0
Fudge...
DC Power TAD 185 or TAD 190.
The OEM alts are reported to produce approximately 50% of what they are rated at. This means your new 110a alt is producing a max of around 55-60 amps. This is not near enough for a diesel super duty - especially one with a dump bed.
Old Oct 29, 2016 | 07:38 PM
coolbrze's Avatar
coolbrze
4wd Low
OK thanks guys, what brands & amps do you recommend for my 6.0L dump truck & where's the best place to purchase?
Old Oct 29, 2016 | 07:44 PM
FordBlueHeart
Ed@Ficmrepair.com can hook you up. He is a site sponsor here and carries the Leece-Neville as well as DC Power. Call him up and he'll tell you everything you need to know.
Old Oct 29, 2016 | 09:33 PM
texastech_diesel
Token Redneck
One of these three, the first unit is IMO the best for your situation:
Old Oct 30, 2016 | 08:59 AM
TooManyToys.'s Avatar
TooManyToys.
I would highly recommend getting the Leece-Neville 230a for your application, a very good price is from XDP with its Diesel10 discount is a good choice from a reputable seller.
With it you will need to increase the alternator to battery cable with a 2ga wire and fuse, and with the dump body I would install improved cables on the battery cross and driver's side negative side, adding a cable between the frame and motor. That cable is even recommended in Ford's Body Builders Guide. That all that necessary as other cables are not necessary.
I use a dump trailer on the farm with quick cycling and we had an F-550 dump at the test facility, I know your situation well.
adammdennis11
Apr 21, 2015 07:40 PM
white Buffalo
20
Aug 30, 2014 12:11 AM
viper29
Jan 14, 2014 11:12 AM
keating8070
Sep 7, 2010 05:43 PM
93 Ford F-150
Aug 15, 2005 06:47 PM
