1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2016 F-250 Platinum Build
Old 03-19-2017, 07:14 PM
AZLugz's Avatar
AZLugz
AZLugz is offline
Got the other light done, finished the removable end caps and got it sanded. Nest is to get the stained and poly coated and cut the lenses then mount them. Once mounted I have to make the wire bridge to connect the up and hide the wiring.
  #92
Old 05-17-2017, 06:56 PM
AZLugz's Avatar
AZLugz
AZLugz is offline
Been a while since I posted but I got some more work done on the lights.
Purchased a prismatic clear acrylic fluorescent light panel, put a 200t blade on the table saw and cut strips of the panel. The panels diffuse the light nicely.
Used onyx (black) stain and the clear coated them. I glued 2" velcro hook to the mount side of the lights and stuck them to the ceiling of the topper then added three screws screws down the length of each and started the wiring. The switches are temporary as I still need to make the deck wings and front and rear control panels but the wiring will stay as is. To eventually hide the wiring there will be a wood cover over the upper part by the lights across the back ceiling groove and it will be stained like the lights. For now, the wiring is velcro'd to the ceiling in the back groove.
Last step was day and night testing, all went well!
White light works great for loading and unloading and also puts enough light out for accessing the drawers. The red lights work great to see in the dark without killing your night vision.
  #93
Old 05-18-2017, 09:23 AM
wizkid00104's Avatar
wizkid00104
wizkid00104 is offline
Nice work. You are quite the craftsman
  #94
Old 05-18-2017, 03:45 PM
AZLugz's Avatar
AZLugz
AZLugz is offline
Thank you, plan to have this one a while and want to make it nice
  #95
Old 08-31-2017, 12:48 AM
Green Power's Avatar
Green Power
Green Power is offline
Ny new mods?
  #96
Old 08-31-2017, 04:44 PM
AZLugz's Avatar
AZLugz
AZLugz is offline
Not really, living on the outside edge of Phoenix, its pretty hot to work on the truck, 109 degrees coming home today. As soon as the weather breaks I will be back on it. Have a lot more planned tho. A fair bit more wood work and electrical including strobe lights underneath for roadside repairs or loading and more in the bed for camping. Hopefully mid sept will get us back in the low 90s
AZLugz
10-22-2016 12:41 PM
Jdeshler
13
06-11-2015 10:36 PM
freerider15
All Other Items for Sale
12-16-2014 03:32 PM
Apocalypse
11-25-2014 08:16 PM
ho_shi
09-24-2013 09:21 PM
Quick Reply: 2016 F-250 Platinum Build
