WOT question
Old Oct 21, 2016 | 10:18 AM
Amicus's Avatar
Amicus
WOT question
Gentlemen,
Yesterday I was being a bad example to my 14 yr old son as I floored it coming onto a county road. Since we straight piped it, we really like to hear it rumble and when he said floor it I was quick to oblige. What I noticed is that the truck seems to stumble a little between shifts. It seems to loose power but than starts to regain it again. It does not do this during normal hwy driving. Is that called lag? Is that just the way our trucks work? Can I do something about it? Will a tuner help with this? My truck is a 06 KR. Other than the exhaust and egr delete, its completely stock.
Thanks
Gilbert
Old Oct 21, 2016 | 04:29 PM
Iaff113's Avatar
Iaff113
Are you positive it hasn't been tuned or had a trans tuning in the past?
Old Oct 21, 2016 | 04:43 PM
Amicus's Avatar
Amicus
Not sure, I've only had it a few months.
Old Oct 21, 2016 | 05:00 PM
WatsonR's Avatar
WatsonR
Some tuning removes timing between shifts so the next gear isn't slammed when the clutch let's go.... like a gradual engaging instead of slam.
Old Oct 21, 2016 | 07:53 PM
Amicus's Avatar
Amicus
There is nothing plug in under the dash. Is there some where else where a chip or tuner be located? Sorry for the dumb question
Old Oct 21, 2016 | 10:53 PM
WatsonR's Avatar
WatsonR
It plugs into the OBD port, then you upload the files to your truck. You'll need a tuner that's not married to a truck and plug it in, if its locked, it will tell you.
Old Oct 22, 2016 | 11:32 PM
Dr.Huxtable's Avatar
Dr.Huxtable
Maybe ask previous owne if he has/kept the tuner if there was even one. Mine came with. Usually though depending on the tune/tuner it should shift much firmer and not delayed like you described
JCS94
Jan 19, 2016 12:36 PM
Wayne Eady
Sep 23, 2013 01:44 AM
alaskaowned
2004 - 2008 F150
Oct 18, 2008 01:58 PM
tippmann87
Jan 23, 2008 10:32 AM
